I have a Donahoe Racing 4.5" lift and did the 350 springs V and B codes a couple weeks ago. The rear is much more smooth riding than it used to be before the spring change. I haven't measured yet but it is at least 1.5"-2" taller with the new springs. Definately notice how much taller the step is getting into the truck now.
I think I'm at about 6"-6.5" total lift. I am running 35" ProComp AT tires but want to go to the 37" ProComp Extreme AT. It will be tight and I might have to rearange the edge of the fender right behind the bumper area, that looks like it will be the place it will rub. I would like to get back a little gearing that I lost when I did 4.30's, that's the reason for 37's.
I was at 44" from ground to wheelwell edge before the springs, now I'm at 46" to 47" depending on how it sits with the springs (V&B's) installed.
Sorry I forgot, I'm running 17 X 9 Robby Gordon wheels.
Greg,
I am running F350 springs, 4" block and F350 leveling kit and the rear spring pack is the modified B pack with Ex bits in it. Take a look at the pics, I have a total of 4" over stock, and rides great, and will ride even better when I get my new shocks in the mail and get them installed...
Garry K
2005 EX LTD 4x4 PSD, V's w/ Summit "gas" leveling kit and modified B's, Radius Rods, 30mm sway bar, Eagle 114 20's w/ 305-55-20" Open Country AT's, Prodigy, Dual-Cam HP hitch, all Black (Secret-Service-Edition)The ExThe Harley EX Road Armor Front Bumper with custom Aluminum winch-hole cover-plate. http://i33.photobucket.com/albums/d9...6/DSC01629.jpg
2001 Nomad 308 (32" w/ 14' Slide) Bunkhouse
4 kids and love to travel and camp!
2001 F350 Dually 4x4 4dr 7.3 6spd 180k and still running strong!
Do you mean, "add a leaf"? It's a cheaper way to go but I would stay away from the add a leaf systems. Some guys on here have used them, (I used one on my old Toyota 4WD) they tend to ride stiffer and give a minimum lift. Caryt and I both have the same setup, a 4.5" DR spring hanger drop kit, blocks in the rear, with V and B codes. It rides really good with 35's.
I've been running my "new" springs for more than a year now. As everyone will tell you, the difference is noticeably better. I also have Air Lift SD air bags installed. The bags are only used when I'm towing the TT.
'04 Excursion EB, 6.0 PS, 4X4, Magnaflow Performance exhaust, Isspro gauges (boost, pyro and tranny), Bilsteins, aFe intake, front and rear leaf spring upgrade w/ bags, 30mm rear sway bar, SCT Xcal2, Red-Head box, Jordan brake controller, Arctic Fox 29V - 20,420# GCW, Everything haulin' me, the wife, the 5 Amigos, Millie and Yogi (our 2 Berners).
