Old 10-18-2005, 12:17 AM   #1 (permalink)
Spring codes stamped on springs?
I bought a used 2000 Limited X 4x4 about a month ago. The springs have been changed and I'm trying to identify what it has on it. It still has the stock front bumpstops and there is 2.25" travel on the driver side and 1.75" on the passenger. The passenger side front spring sags a lot more than the driver side.
Is the spring code stamped anywhere on the springs?
2000 Excursion 4X4 Limited 7.3psd
AIS w/fender sleeve, Zoodad, TAG, Shimmed fuel reg, AIH delete, Banks Six-Gun & tranny temp gauge in pillar pod,Rancho RSX, Sonnax/tricum, 203 thermostat and Billet housing, Coolant filter, Aeroturbine, Walker BTM, Xcal 2 with Tipton tunes
Coming soon: Requlated fuel return system, WW
otterdiver is offline
Old 10-18-2005, 12:41 AM   #2 (permalink)
FamilyRide's Avatar
Re: Spring codes stamped on springs?
Nope. Part numbers change so for one that long ago, it may be near impossible.
The difference in "sag" is about normal, even for brand new before any settling. Not saying it's right, but it's normal.
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 10-18-2005, 05:24 PM   #3 (permalink)
Wow that is a lot of sag side to side
1/4" low on left (drivers) is normal as there is just more weight on left with steering gear and all
guessing sounds like a V on left and something gone bad on right.
Vs add 1.5 so 1.5 + .75 (typical older X) = 2.25
There are part numbers on the springs, stamped in the end of the second leaf check to see if the same. And as said above the numbers are not reverse codable as far as any one here knows and we have been trying to find a way to "DECODE" front springs for over three years that I know of.
Bruce AKA spring Guru
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 10-18-2005, 10:20 PM   #4 (permalink)
FamilyRide's Avatar
Mine's about 1/2" difference too, and was 3/4 when new. Ford's "Spec" is 5/8" difference for the front and 3/4" for the back.
I'd sure like for it to be less, and more than 1/2" to the bump stop would be nice too. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Old 10-19-2005, 04:20 PM   #5 (permalink)
MotionMan's Avatar
No #s, it is on the door.
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium.http://community.webshots.com/user/stellinm
MotionMan is offline
Old 10-19-2005, 05:26 PM   #6 (permalink)
Wow, looks like I may have to change the springs just to know what I've got under there. Really don't like the sag on the passenger side. Was hoping they would at least mark what code the springs are from the factory. The drivers side front spring has an X stamped on it and is highlighted by a spot of paint, the drivers rear has a B similarly marked. No such marks that I remember on the passenger side. Need to crawl under again and see. So, someone could have marked them after the factory but I can't really know for sure. All of the spring bolts/U bolts have been recently removed and the front bolts are inserted from the outside so I know things have been changed.
Was kind of hoping the markings meant that I had X's and B's but... I guess that's one of the joys of buying used... by the time I go through everything I'll know exactly what I have and will have the upgrades I want! At least the price was right...
» Sponsor Links
»Garage Storage and Cabinets
