Spring Issue - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 05-22-2009, 08:41 PM   #1 (permalink)
Cool Spring Issue
I FINALLY INSTALLED MY REAR SPRINGS BUT HERE IS THE PROBLEM NOW MY EX RIDES LIKE I HAVE NO SUSPENSION IN HE REAR,ITS VERY HARD WHEN GOING OVER BUMP LIKE I AM CONSTANTLY RIDING ON THE BUMP STOPS I ALSO INSTALLED CAL TRAC TRACTION BARS MAY BE HEY ARE NOT ADJUSTED CORRECTLY SO PLEASE THANK YOU ALL FOR ANY INFO OF HOW TO REPAIR THIS
2000 excursion,full banks exhaust dp-tunner,edge stacker filter and gauges 305-60-16 inch tires on 16 by 10 inch rims,helwig rear sway bar,kenwood head unit and a 10 ind drop down screen totaled
NEW ex 2004 6.0 limited with pmt exhaust and a sct tunner
rsg4ever is offline
Old 05-23-2009, 07:11 AM   #2 (permalink)
therabbittree's Avatar
stop yelling at us... Ie : Capitals. What Spings did you install?.. how are your caltracs installed?.. any pictures?
Thanks,
Deo
2000 Excursion XLT 4x4, 12V P Pump Cummins, 0-ringed head, AE G56 6 spd, southbend FE clutch, guages, lazer dv, 370's, Black Vinyl floor, 285 Nitto Dura Grapplers, 4" remote BD Exhaust Brake, 4" exhaust, Working on Twin turbos HX50 9cm and BHT3E 20cm with tial external wastegate, looking for 2008 XL front clip
http://picasaweb.google.com/therabbittree/Excursion02#
2005 Excursion Eddie Bauer 4x4, 6.0L, Rear Capts. Dark Green
1992 W350, srw, dump flat, 5sp, pods
1996 Passat TDI Wagon, worked
therabbittree is offline
Old 05-23-2009, 10:02 AM   #3 (permalink)
sorry i didnt know cap was a form of yelling i installed f 250 front an rear springs the cal trac bars are the ones which prevent axle wrap and load the springs i will try to provide pic today
rsg4ever is offline
