06-24-2008, 07:01 AM
#1 (permalink )
spring question
i have a 2001 X. I've read and read the old spring posts but have a question. At this time there is about 2.5" between the spring pack and the frame, and the bump stops have been ripped off (from this apparently) I just want the front to sit back like it should most likely level with the rear. Do i need a set of V code springs? or will this be to much height? thanks for your help.
2001 Excursion Limited,4x4, toreador red, 4" turbo back exhaust, DYI Tymer intake
92 F350 CC SRW,7.3 E4OD 4x4
4" lift
35" tires, 4.10,
4" exhaust straight pipe
ATS nwg turbo, rebuilt and balanced, holley red, new IP & injectors, rebuilt heads by me
A pillar triple pod, auto meter phantom gauges,
pyrometer, boost, trans temp, oil pressure & water temp
future upgrades :
formerly known as; pullmyfinger
http://community.webshots.com/user/pullmyfinger76
06-24-2008, 09:21 AM
#2 (permalink )
V codes will give you about 1"+..you want these springs! Also get a set of B code SD rears and mod them..PM me and I can help.
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
07-08-2008, 04:29 PM
#3 (permalink )
pm sent, cary
4" lift
35" tires, 4.10,
future upgrades :
Linear Mode
» Site Navigation
» Other Sites
