Re: springs .......again
i've been waiting for the above post..i've been looking at spring posts like a deer looking into headlights..
then i saw you guys all have 4x4's.. [img]/ubbthreads/images/graemlins/confused.gif[/img]
(eyes glazed over again)
That does not change the F code mod
ALL Xs All years used the same G code rears, only difference is the 4x4s had the added anti-wrap leaf that is not used in the above mod any way.
as far as front springs there has been some work done or you could just add urethane spacers. To my understanding there is not the travel problem on the 4x2 that there is on the 4x4.
Hope this helps
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Just about finished! (never tell the wife you are done)
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
