Re: Starting Problem
I don't thik I would buy into that one.
About a month or two ago I towed about a 6k load over in to TN and was wanting to get fuel when I got into TN as it is less than here in NC well I went a bit to far when I pulled into the station it was very full I I could not find the one deisel pump in the middle of the gas pumps just to many cars and trucks in the way and I had 24' of trailer behind me.
Any way it started bucking and then stalled, started right back up moved the truck around again did it again may have stopped, stalled 3 or 4 times before I got to the pump. Filled up and drove away no problems.
Also learned that E on the 05 does not mean 2.5 gallons to go (like the 02) it is EMPTY! well not empty as it only took 42.5 gallons I had put over 44 in the 02 several times and never ran out or stalled at the pumps so somthing has changed. But then I did have the intank mods done on the 02 and I KNOW the pickup was on the bottom from the factory.
Stalling and or not starting is not normal for these so I would seek help and try to get an answer. But I do know that is difficult when it "runs per spec" every time you take it to the dealer.
I am about to start one like that myself I get a missshift about every 100 to 200 miles. But that is fairly often for me as I have almost 10K on the 05 I picked up June 27th. [img]/ubbthreads/images/graemlins/smile.gif[/img]
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
