Steering components question
Having the second replacement steering gear box put in today. First one did nothing for the play in the steering wheel. Still able to go about 1.5 inches EITHER direction with the steering wheel BEFORE the front tires move. I am having this installed by a reputable alignment shop. BESIDES the steering gear box, what else could possibly cause this issue? BTW, I have already replaced the tie rod ends, steering stabilizer, and the front sway bar bushings to TRY to correct a wandering issue. The steering gear DID fix the wandering issue, but there is still WAY to much play in the steering wheel. The mechanic has checked everything he can think of in the steering components (rag joints, linkages in the steering column, adjustment nuts on the gear box itself). The ball joints are good according to him. Just the play in the steering wheel is way out of whack. Any other items to have a look at? Is there something IN the steering wheel itself that could be worn out or needs adjustment? I am looking for any suggestions you folks might have :~>
Thanks for the time and the information,
greg
