I have asked this before but why is there so much play in the steering...I drove my freinds F250 and it is great with no play. Anybody else have this problem. I love my X but it gets aggravating at hwy speeds........It's almost like the steering box is not meshed right with to much play in it.... [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Thanks in advance..
05 King Ranch Dually w/ every option offered ridding on 22.5's
06 Harley Davidson F350 w/every option offered ridding on 20's
08 King Ranch Dually F450 w/every option offered
ridding on 19.5's for now????
Check this October Thread as it may help some in how to adjust the steering box' play [img]/ubbthreads/images/graemlins/smile.gif[/img]
__________________ 2002 Ford Excursion 7.3L 4x4 XLT 9th Annual Powerstroke Rally this Oct 3-5 2008 in Caddo Mills,Texas CLICK HERE for more Information & Register Here
That is a great post but should I have this problem with a 2004 X with 8000 miles???????????
8,000 miles I wouldn't think so,maybe a trip to the dealer for them to adjust it for you under warranty?
Hope you have a good dealer by you that won't tell you it's within spec [img]/ubbthreads/images/graemlins/tongue.gif[/img] [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
I haven't adjusted our steering as it's okay but wouldn't hesitate to do it by the directions given [img]/ubbthreads/images/graemlins/smile.gif[/img]
CHPmustang is right. And most people come away fomr the deaelr after being told that "it's within spec" becasue FOrd says it is and won't pay them to adjust it.
I've also never heard anyone that said it was anything but quick and easy to adjust themselves.
I complained that mine just would not track well and was fatiguing to drive. They replaced all 4 ball joints due to binding. I have not been able to drive it a lot to tell if there is much improvement due to the fact that I am now waiting for a new wiring harness to fix the stalling/quitting problem that just started at 18K.
2004 Ford Excursion 4x4 Eddie Bauer 04 6.0L B/D 10/24/03
2001 TrailBay 31BHSS W/Slideout
1964 Karmann Ghia Coupe
Most of the wandering ailment common to Excursions is not originating at the front end of the truck. Believe it or not, the rear axle is inducing its own steering because of the X's weak leaf springs ("weak" in comparison to OEM springs on F250/350/450/550 models). Wandering occurs when you get spring-wrap in the rear leaf springs, but the wrap is uneven side to side. That allows the rear axle to get out of square with the vehicle's centerline, and rear axle steering (or you can call it a form of bumpsteer) is the result. One fellow told me he rode alongside while his wife drove their X while towing a TT, and he could actually see this happen. I installed a couple rods on mine that work similar to ladder bars (except these attach to the leaf springs and not the frame), and the wandering ceased ... completely.
(I've pasted the same comments above in at least 3 different threads, all dealing with poor on-center tracking.)
Hoowasat, Can you post up some specifics (parts used, attachment points, etc.) and pictures? I am quite interested in your fix. I think I have seen a similar set up advertised for travel trailers, but can’t remember where.
Thanks, axtinc
Thanks, axtinc
I would also like to have the same info on parts etc.
Thanks!
David
__________________ http://community.webshots.com/album/124311395bOZfDt]
2004 Excursion Eddie Bauer 6.0 PSD 4x4 in Oxford White. Order date 1/16/2004, Build Date 2/9/04, Ship Date 2/10/04 Delivered 2/17/04. All options accept DVD & Chrome Running Boards. Accessories already purchased include Turbo Diesel Badges, Mud Guards, 4x4 Lighted Hitch Plug, Euro Style Rubber Antenna, Pet Partition, Adjustable Tire Step, Husky Mats & Cargo Liners, Tri-Ball Adjustable Drawbar, Diablo Predator, PIAA Silicon Wipers, AFE with Pro-Guard 7, Stanadyne Performance Diesel Formula.
2005 Arctic Fox 32D RV Travel Trailer
2004 Hensley Arrow Hitch
04 BrakeSmart Controller.
1997 PSD-250HD, 4x4, 5 Speed, standard cab, downpipe, buried muff., 4.7 advanced, Baldwin open air element, Fumoto F-111 plug, Isspro pyro and manifold pressure gauge on pillar, Gulf Coast oil by-pass filter, M/T Baja Radial MTX's.
-SOLD- 2003 Excursion 6.0 Oxford white, Eddie Bauer 4x4. Turbo Lifesaver, Oil Guard by-pass, Fumoto plug, Rancho RSX'x up front, Rancho RS5410 stabilizer, custom rear air shocks, 30MM rear stabilizer, Radius-Rods by Landyot, Ranch Hand-front and rear, 5 IPF off road lights, Marinco heater plug receptacle, 305's Cooper Discoverer S/T on MT classic II rims, pillar pod with Isspro pyro, trans temp. & boost, V and F code springs.
"The polite society, is not one which nobody is armed, but rather one in which everybody is..." Robert Heinlein.
As I recall, the front end parts tend to be "tight" and ford has devised a complicated way to attach a torque wrench to it and then pull back and forth before telling you that it's within spec.
Also, the rear end slop really is an issue and a Hellweig anti-sway bar helps.
clam the powerstroke grinch
2000 Excursion LTD 4x4
Slightly tweaked HPCR 5.9 Cummins
Allison 1000 5 speed auto
