Old 01-05-2004, 12:15 AM   #1 (permalink)
Stereo wires connection ??
Does anyone know which color wires on the rear headphone connections go to right and left. The connection I am looking at is the one on the rear of the center console where the rear passengers connect there headphones.
Thanks..
2008 F450 Lariat 4X4, Line-X, Pace Edwards bed cover, B&W Gooseneck, B&W Companion hitch, Firststone Air Bags. Everything else stock.
2002 Excursion Limited 4X4, 7.3 with Banks Stinger Plus, AFE, Rear sway bars, Bilstien Shocks
PSDCool is offline
Old 01-11-2004, 11:26 PM   #2 (permalink)
Re: Stereo wires connection ??
The wires that are used to create the headphone outputs are the speaker wires for the rear speakers. The control panel recievs a raw speaker and the sends it back out to the rear and middle speakers.
Colors and pins as shown in the 2003 X Audiophile sound sytem schematics
Raw left + is GY/LB (6) - is TN/YE (5)
Raw right + is OG/RD (2) - is BN/PK (3)
Left out + is TN/WH (7) - is same as raw (5)
Right out + is TN/LG (1) - is same as raw (3)
() denotes the pin number at the control panel connector
Jim
PowerTug
03 Excursion Limited PSD 4X4 3.73 LS
Build 3/20/03, C95 Injectors, Updated VGT, December 04 flash, Harpooned, Second Hot Water Shutoff Added for A/C, Updated DVD Entertainment Center wireless headphones, SiverStars, Fog Light Retro with 9005 SilverStars
Average MPG 17.5?, City MPG 16?, Highway MPG 19.5?, Towing Bass Boat MPG 17?
jnomura is offline
Old 01-16-2004, 01:09 AM   #3 (permalink)
Thanks..
Thanks for replying.. If I want to splice in a wireless headphone transmitter. Would I be correct to tap into the raw wires.
PSDCool is offline
Old 01-16-2004, 08:00 AM   #4 (permalink)
That will probably blow out the transmitter. You need to install a line level converter and send its output to the transmitter. I installed the converted in the back of the center console. Then ran RCA cable under the drivers seat up the B piller and over the the entertainment system to the transmitter.
03 Excursion 4X4 Limited 6.0 PSD, Mineral Gray Metallic Born on: 22-Jan-03
Upgrades to date:
F250 Heated Tow Mirrors with markers and signals
Wireless rear sound
Garmin StreetPilot 7500
Pyle PLA1585 5 Channel Amp
Pioneer 4-Way's in sides
Dual Punch 10" enclosed subs in rear
Wood trim dash
Code Alarm Tw-1 Remote Start
Helwig Sway Bar
Lighted Blue Oval Rear
2005 Modified Grille
Sho-Me Strobes Front and Rear
7" Visor LCD Monitors L&R
Back up Camera in 3rd Brake light
Parrot CK3100 Bluetooth
*NEW* Right rite air bags
on board air system.
Siege engneering air horns
02 BMW X5
52 HD FL
97 HD FLSTS
06 HD FLHTCUSE
dspange is offline
Old 01-16-2004, 08:24 AM   #5 (permalink)
THEBUNDO's Avatar
My Photos: (14)
Ditto that. Line level. You'd have to have your volume almost down to nothing to not blow up the transmitter otherwise.
THEBUNDO is offline
Old 01-16-2004, 12:47 PM   #6 (permalink)
Does that mean I cannot connect from a headphone jack into the RCA input jacks of the wireless transmitter. Sorry for the dumb questions.
PSDCool is offline
Old 01-16-2004, 01:08 PM   #7 (permalink)
THEBUNDO's Avatar
My Photos: (14)
You would have to have the volume low in that situation too, unless the transmitter has a circuit to correct for that. But if the directions say to hook to "Line Level" or "Line Out" or to an "Aux" or "Auxillary" (which means line level), then that is what you need to do.
THEBUNDO is offline
Old 01-17-2004, 05:27 AM   #8 (permalink)
PSDcool,
DO NOT CONNECT DIRECTLY TO THE HEADPHONE JACK !!!!! [img]/ubbthreads/images/graemlins/phoney.gif[/img] It will blow out the PC board that produces the headphone output. The designer of the circuit floated the 'ground' side of the headphone common at a voltage different from ground (a really poor decision). The RCA inputs to the transmitter have the shield side connected to chassis ground and when you connect the headphone jack and the RCA together current flows that heats up components and the board will fail in a short time. I know this because I did this myself and had to replace the control panel. The symtom of a blown control panel is that it will no longer control the radio remotely and you can't turn on the headphone mode. Do use a line level converter. If you will PM me and send a Email address I can send you a JPEG of the wireing diagram with the line converter drawn in. Does anyone know how to post a JPEG so it is available to those who might need it?
Jim
PowerTug
jnomura is offline
Old 01-17-2004, 08:13 AM   #9 (permalink)
THEBUNDO's Avatar
My Photos: (14)
email me the jpeg, then PM to tell me to check my email. I'll host it for us all to see.
THEBUNDO is offline
Old 01-17-2004, 04:27 PM   #10 (permalink)
THEBUNDO's Avatar
My Photos: (14)
Click Here for PowerTug's wiring diagram. His email stated:
"This PIC is from the FORD chassis wiring manual model years 2003. My penciled in part is what I added. Note the R and L inputs are
should be reversed for proper R-L channels (I drew it incorrectly)."
Hey Jim, just realized you are in San Jose.
THEBUNDO is offline
Old 01-18-2004, 02:28 AM   #11 (permalink)
PowerT and The_B,
Did exactly as per your drawing. I am using a Clarion WH105 RF Wireless transmitter, a IEC AULOC adjustable line output converter.
I tapped into the wires at the rear bottom of the center console control panel as per your drawing and it works perfectly. The dual/single mode seems to function also. Since there is no "switched" pos there I'll have to run a wire from under the dash to get switch power to that location. This must be a Cali thing, I'm down here in So Callif. I'll have it done tomorrow, next trip I can listen to what I want and the kids can watch the movies...
Thanks for all your help..
PSDCool is offline
