Strange Electrical Issue 2003 Ex - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 12-27-2009, 11:29 AM   #1 (permalink)
Couple weeks back, wife noticed Ex would start but heating/AC controls would not come on. This was intermittant problem. Christmas Eve I was backing out of parking spot and Ex died. Lots of clicking, blinking lights, but acted like batteries dead. Played with switches, shifter, waited for while, and was able to start and get home. Seemed to start and run fine in the driveway that evening. Started yesterday to move to shovel snow, Ex died after few minutes. Now nothing, no lights, no clicking relays. Batteries appear to be fine. Tried to charge them but they show in fine condition. Noticed the Theft light blinking a lot during some of these problems. When I started yesterday, there was a lot of clicking noises on the relay panel. Just plain dead now, no interior lights, nothing. Suggestions for places to start looking? Does this sound familiar to anyone? Thanks.
MGHAMS is offline
Old 12-27-2009, 12:37 PM   #2 (permalink)
Batteries would be 1st whether or not they appear charged or good. Second would be ground issues.
2001 X, 4x4, White, Limited, PSD,. Oil Guard, Stull 6099 Grille, AFE Intake, X Monitor, Sonnax/Tricumulator, Mobil 1 ATF w/Racor tranny filter, PHP Custom Burn Chip, Walker BTM, W Code Frt Springs, Procomp Add-a-Leaf Rear, Rancho 9000XL's w/5406 SS. Pics @ http://community.webshots.com/user/txangler32
TXANGLER is offline
Old 12-27-2009, 11:21 PM   #3 (permalink)
It is all related. I would add alternator to the list. When my alternator finally gave up, the transmission wouldn't work right, theft light was flashing, anything electronic was acting up.
Based on other posts about alternators causing all sorts of unrelated issues, I was pretty sure the alternator was the issue. The lady at NAPA was apologizing that my alternator was bad. I was glad, if my alternator wasn't bad, I was going to be totally stumped or have all sorts of repairs to make.
Steve
2000 7.3L PSD Excursion
4" MBRP 409 Turbo Back
Hellwig Swaybar
Isspro EV, Overhead 3-Gauge Mount
300K and rolling right along
Ford AIS
6.0 Liter Tranmission Cooler
BoilermakerSteve is offline
Old 12-28-2009, 01:46 PM   #4 (permalink)
Check battery voLtage to be sure with a decent meter.
Should be 12.3 to 12.6 prior to starting
Right after starting about 11.4 to 11.6 while glow plugs are on.
Then should go to 13.4 to 13.8 and climb to 14.x with next to nothing on even at idle.
If you have all of this you know the alternator is good.
If you are over 12 volts and it won't start check grounds.
When my alt went bad a few weeks ago I could not get anything above about 13.4 volts and with any load it was down hill from there.
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Just about finished!(never tell the wife you are done)
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 12-30-2009, 01:21 AM   #5 (permalink)
Check your ground cable to block, ill bet the cable is about to come off the motor, it was a common problem with the 03s, in fact mine almost caught fire because when the cable falls off, other smaller ground cables take 100 percent of the load and get red hot and burn off, be careful
2011 KR Dually CC 4X4 Royal Red
2006 KR Dually CC 4X4 ,True Blue
2005 KR Dually CC 4X4 ,Dark Copper,sold 12/30/10
2005 Eddie Bauer Excursion 4X4 ,White
All purchased from Bobby Williams At Sunrise in Fontana
STMPDUST is offline
