Re: Strictly Dyno
The numbers (HP and Time) don't add up. [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img]
You dyno'd stock at 320 RWHP in 5th gear,
The motor only puts out 325. [img]/ubbthreads/images/graemlins/shrug.gif[/img][img]/ubbthreads/images/graemlins/shrug.gif[/img]
Where is the 18-20% drive train loss.
Also at 320 HP, you should be running in the 15's
Maybe you could help me out , what type of rwhp is needed for a fully loaded Ex with a full tank of fuel and a 235 lb driver at 3200 ft elevation and 90 degrees of heat ,to go 81 mph in the 1\4 mile, my guess is somewhere around 300+ at the tires, we Dyno around 30 cars a week , stock ls1 cars make over 300 at the wheels and are rated at 300 from the factory, maybe they are under rated from the factory, also there were several other v8 trucks(gas) at the track that were running 18+ sec in the 1\4
Todd
2006 KR Dually CC 4X4 ,True Blue
2005 KR Dually CC 4X4 ,Dark Copper
2005 Eddie Bauer Excursion 4X4 ,White
