Old 08-08-2003, 01:53 PM   #1 (permalink)
Stuck Front hubs
OK, I am buying the 7.3 2000 PSD Excur. The truck has 39K, and I can't budge the front hubs. Any one run inot this?, and about how much. I read on another post it was about $125??
Thanks,
Rob
70boss is offline
Old 08-08-2003, 02:20 PM   #2 (permalink)
Re: Stuck Front hubs
If you don't want the "auto" mode then you can replace them with warn premiums. I've had good luck with giving the hub area a "hosing down" with silicon spray and working through their range once a month.
Regards,
Dave
2002 Excursion Limited - 7.3 PSD, 4x4, Auto. Tekonsha Prodigy Controller. ISSPRO EV Gauges in A-Pillar mount. Diesel Turbo Lifesaver. Pre-pump Mod. SCMT-Trimode. AIC. Back Door storage bins. Banks 3 1/2 inch Monster Exhaust. AIS. "U-Code" Springs. Powerstroker Exhaust Brake. Husky Liners. Bilstein Shocks. ART Brakes, Helwig Rear Anti-swaybar. Zoodad Mod. Airlift Rear Airbags. Racor 3550 CCV. Forest River Wildcat 26FBS TT.
2003 VW Jetta TDI - completely stock and 49mpg!
2003 Kubota B2910
dmftoy1 is offline
Old 08-11-2003, 12:23 AM   #3 (permalink)
Had the same problem on my 02, they were very stiff,
Then I had the right front hang up and would not release, So I locked them both up, with the dash Switch in 2WD until the dealer replaced them both under Warranty. I had sprayed them some and silicone did seem to work better than WD-40. Seems to be a typical problem for a lot of SDs that do not get the hubs "exercised" often.
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 08-12-2003, 06:23 PM   #4 (permalink)
I was having the same problem. Instead of messing with the stock ones I bought some ProComp hubs made by Mile Marker. They are all metal and cost about $140. I plugged the vacuum lines going to the stock hubs. I don't have the convenience of going into 4 x 4 without getting out, but I don't use it too much in So. Cal.
'00 Excursion Limited, 4x4, PSD. 6" ProComp lift, Weld (Stone Crusher) wheels, 35" ProComp tires. Dual shocks up front. Airaid air intake. Straight piped. SCMT-80hp, Western Diesel triple pod gauges.
gschneid is offline
Old 08-26-2003, 02:51 PM   #5 (permalink)
I too have had this problem. Removed my hub lockers, disassembled, cleaned and immersed in oil for a few hours. Now they are good as new. Just have to keep them lubricated. Those O-rings have a nasty habit of drying out and sticking.
I have now made it a habit to give them a squirt of oil when I do the oil changes. At which time, I also "excercise" them a bit.
NEVER....I mean NEVER use tools on these lockers or force them to turn. If you do, you will almost surely destroy the O-ring. And as far as I can tell, these units are not serviceable.
<font color="421193">**FOR SALE** -&gt; 2001 4x4 Excursion-LTD.,7.3L PSD, Chestnut, 3.73L/S, AIC, Michelin LTX M/S "E", Tekonsha Prodigy, Triple A-pillar w/VDO Gauges, Hypertech PPIII, U-Code Springs, Bilstein Shocks, Rancho Stabilizer, Rear Hellwig Anti-Sway Bar, ART Brake Rotors & Pads, EPI Exhaust Flex Pipe, Husky Floor Liners and Molded Mud Flaps, WeatherTech Vent Guards, 24" Wipers, Fuel filler neck mod. Fog light switch mod., Rear Aux Lights, Dual Alt. Upper Radiator Hose, Disabled key-in chime.</font>
Toolman1 is offline
