Stuck rotor - any tips for getting the #@%#$ thing off ?? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 04-11-2008, 04:36 PM   #1 (permalink)
Sudsy's Avatar
Replacing the front rotors and pads with Powerslots and Hawks - ran into a little problem.
Drivers side front 2000 4wd 7.3 PSD has a badly warped front drivers side rotor. I got everything else off (other side was a piece of cake) but the rotor has no desire to come off the hub
I've sprayed it, soaked it, beat it half to death with a dead blow hammer, even gave it a few softer whacks with a ball peen hammer
- it ain't moving
Now what ??
Sudsy is offline
Old 04-11-2008, 04:45 PM   #2 (permalink)
klhansen's Avatar
My Photos: (169)
BIGGER HAMMER!!!
If you're replacing it, don't worry about hurting it. The heavier the hammer, the quicker it will come off. It'll just laugh at a ball peen.
You've got to deafen those rust molecules that are holding hands, keeping it stuck on. Make 'em let go and cover their ears.
Hard or no-start? Check Here
klhansen is offline
Old 04-11-2008, 04:48 PM   #3 (permalink)
Sudsy's Avatar
5 lb sledge and a fit of anger took care of it
Sudsy is offline
Old 04-11-2008, 07:06 PM   #4 (permalink)
Firebomb_k's Avatar
Yes when in doubt use a bigger hammer. I perfer an 18lb sledge myself.....it gives such a perfect twang.
Travis
1996 F-250 Powerstroke , Ext Cab Long Box, 4x4
380,000 Miles Strong
Dana 60 Front Axle
Banks 100 Hp Big Hoss Chip
Banks Pyro and Boost Gauges
2001 Excursion Limited HD , 4x4
182,000 Miles Strong
BTS Transmission, 6.0 Transmission Cooler,Rear Air-Lift Bags
Firebomb_k is offline
Old 04-11-2008, 09:14 PM   #5 (permalink)
detroitfd's Avatar
When mine got done, he used an air hammer attachment on the compressor and both came off in 5 seconds.
Jerry
My PSD X
2000 Excursion 7.3L PSD 4X4
DP-Tuner F5 : no start, stock, 40T, Decel, 80T, 80E - AutoMeter A pillar w/ 3 Phantom gauges - DIY Tymar intake w/ S&B conical filter - Zoodad mod - Suncoast Extreme Duty Trans rebuild w/ TransGo Shift kit, Amsoil synthetic ATF & Magnefine inline filer - BD Triple Disc Billet Torque Converter - 4" Stainless Steel Turbo Back (4" down pipe) Magnaflow exhaust - ATS Turbo housing and 4" intake sleeve - Turbo Master Wastegate Controller - HX Oil Crossover - Morse Ceramic brake pads - Monroe Reflex Shocks - Energy Suspension Bushings - IC foil wrap delete - Fumoto Oil Valve - 08' Aluminum Rear Differential Cover - White Night reverse light system - Garmin StreetPilot c340 GPS - 6.o tranny cooler - Dieselsite Coolant Filter w/ CAT ELC coolant - Amsoil Single Bypass Oil Filter w/ Rotella 5W40 synthetic oil - APC white gauge cluster face - Dual in-dash DVD w/ Infinity Reference speakers & Blaupunkt 200A powered sub - 4.5" LED marker/turn lights in front bumper - ViAir HD onboard air system w/ 380C compressor, 2.5 gal tank & Grover stutter tone air horn - FireStone RideRite suspension air bags -
TOWING:
2004 Dutchmen 31BH travel trailer
detroitfd is offline
Old 04-12-2008, 03:58 AM   #6 (permalink)
clamgulch's Avatar
LMAO!!!! Well put.
clam the powerstroke grinch
2000 Excursion LTD 4x4
Slightly tweaked HPCR 5.9 Cummins
Allison 1000 5 speed auto
clamgulch is offline
Old 04-12-2008, 03:58 PM   #7 (permalink)
Worst case, you will need to pull the unit bearing and put the whole assembly in a press. I had to do this on a chevy a few months ago.
2000 Excursion 4x4, X codes/F350 blocks, 285 Bfg At's load range E's, 4" turbo back MBRP, Stage 1 AFE, Gauges, Dp tuner F5 high idle/40 tow/80 tow/80 economy/120 race/140 race, Cryo'd rotors/performance friction pads. Weighing in at a portly 8500lbs with 1/2 a tank of fuel!! Built for towing
2dedge is offline
Old 04-12-2008, 04:30 PM   #8 (permalink)
Send a message via ICQ to coldair
take a 3 lb sledge ans smack in around the center. the vibration usally will amke it seperate from the hub
2002 Excursion LTD(PCM:NQW5)Pheltech Tru-Cowl Induction Hood BTS transmission FASS and ITP fuel system, 38/15.5/20 Toyo's on Weld 12" wide wheels,15k warn and warn 9.5k rear 4:30s ARB air lockers front and Dana80 rear. Trail ready front bumper,Road Armor rear bumper light force driving lights, PIAA backup lights,Dakota digital gages, F5 DP tuner chip,Hypermax stage 2 injectors,4" exhaust, 11" Edge lift, King shocks, edge crossover steering, ORU ram assist steering
OneUp ladder bars,TN turbo, Dynatrac conversion kit. Alpine F1, Zapco amps. two dc1100.1, three dc1000.4, 1 dc750.2, driving seas reference series front stage and Zapco competition rear fill and 2 Jl audio 13w7 subs
AP Racing big brakes, Amp Research running boards
coldair is offline
Old 04-12-2008, 04:45 PM   #9 (permalink)
rock_doctor's Avatar
Put a block of wood under the rotor and slowly let the truck down onto the block of wood. It will break free just be sure to not let it down too fast you don't want the rotor to flop forward onto the studs. It can crack.
2005 Excursion w/ 6.0L PSD
2008 FX4 F250 CCSB w/ 6.4L PSD
rock_doctor is offline
Old 04-12-2008, 04:46 PM   #10 (permalink)
turbodave's Avatar
Are the rotors seperate from the hub assembly? If so, I wonder why my local stealership told me there's a set of grease seals required with a rotor change???
TurboDave, EWCS(SW)USN Ret
H&N Turbo 6 Racing
Seviervile TN
A MAN AND HIS TRUCK, IT'S A BEATUFUL THING
01 Excursion LTD (EBM3) 7.3L, PSD, Turbo, 4X2, TTS Race Magnum chip (original owner)
86 GN (original owner)
87 GN (second owner)
08 Honda Accord EX-L
My Photo Gallery
turbodave is offline
Old 04-12-2008, 05:30 PM   #11 (permalink)
Turbo Dave since you have a 2wd then your rotor does have the bearings mounted inside. If you need to replace the rotor you will need to install the bearings, seal and make sure you grease it all real well. The original poster has a 4wd so the rotor is mounted on a hub assembly that contains the bearings and studs. It is a different animal.
Old 04-14-2008, 02:07 PM   #12 (permalink)
Good idea to use never-sieze between the rotor and hub when you reassemble it. I also use it on the lug nuts so if my wife is driving it and has a flat, she can get them off.
boatpuller is offline
Old 04-15-2008, 03:06 PM   #13 (permalink)
turbodave's Avatar
So if I understand you correctly, my rotors are NOT seperate from the hubs???
H&N Turbo 6 Racing
Seviervile TN
My Photo Gallery
Old 04-16-2008, 01:26 PM   #14 (permalink)
Dave - You understand correctly.
Hope this helps,
John
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
JADFPE is offline
Old 04-16-2008, 03:31 PM   #15 (permalink)
I found a plumbing torch and a 12lb sledge were the answer. My front rotors weren't too bad, but since I got 100k miles (160 k km) and about 3.5 years on my stock brakes, the rear rotors were amazingly difficult to remove.
I bought an MBS plumbing torch for the task (although the standard propane probably works). I used the torch to heat the portion of the rotor that was in contact with the hub. After about 2 or 3 minutes, I shut off the torch and went at it with the sledge. It came off with a fair amount of effort. I added anti-seize to the replacement before I mounted it.
I had tried the 12lb sledge for about 20 or 30 minutes before the torch. I was not effective for me. I was not trying to save the rotors, but no level of violence seemed to help.
A little bit of heat is magic. Whenever you're doing this, heat the outside thing. IE: bolt stuck in something, heat the something, not the bolt. You want to expand the outside thing with heat, not the inside thing.
I would assume you want to be careful not to cook the hub or it's grease, etc. There's a lot of metal on this truck --- so it's not that hard to heat the rotor without significantly heating the hub.
2004 Excursion EB 6.0 Estate Green. As yet, unmodified. Delivered 2004-07-14
Zaphod is offline
