I previously owned an Expedition with the auto hubs. All I did was flip the switch to 4WD when it snowed or I went off road. How does the X work with both the switch and the manual locks. I thought I've read that all I have to do is turn the switch in the truck to go into 4WD? Are the outside locking hubs insurance or protection to make sure it stays in? I really would like to know how the whole system works...I just don't!
2000 X ltd.,white/parchment 4X4 loaded,285/75/16 BFG's,dvd,converted 06 oem grill,Xtint,New style clear headlights & clear corners w/ Plasma white bulbs,Fumoto,cut front bumps,Bilstein's,ass'd X badges & ass'd door PSD badges,ISSPRO EV gauges,clear cab lights, Wet Okole front seat covers, Weathertech visors,Pro-Comp steer stab.,Tymar Perf.intake, AIH removal mod w/boost tap,muffler delete turbo back Magnaflow 4" SS exhaust,WW,ATS Housing,Turbomaster controller,CCV Bypass,Edge Evolution Programmer(Extreme every day tow heavy in 80HP Mode),Power Slot rotors all around w/Hawk LTS pads,Duralast Gold Batteries, etc.); BTS tranny & new programming if oem ever dies.
In betweeen boats so now I have a custom 2003 HD Heritage Softtail I Love! Will return to boating when sons get older at 2mm LOTO, MO! Ride with friends now...Harley much cheaper on fuel! http://community.webshots.com/user/jweiler27
Work hard, play hard; strive to be the best at whatever you are doing!
When the hubs are in the auto position they do just that the automatically lock the hubs via some sort of vaccuum technology.
The lock position bypasses that vaccuum technology and locks the hubs in place manually. Either method requires that the ESOF be switched to 4x4.
The lock position is a backup in case the vaccuum method fails. I'm kind of a new Excursion owner but that is how I understand it and to be honest I'm not sure how you know if the hubs locked or not via the automatic method.
I do know that if you switch the hubs to lock you can reach around and try to turn the universal joint and if they are indeed locked they will NOT spin.
West Deptford, Gloucester County, Southern New Jersey
2002 Black Excursion XLT 6.8L V10 ( Pics) - Timbrens, 2WD Lift Gate Struts, PIE adapter, Cell Phone Harness. 2002 Ford Explorer - Wifey's ride. 1999 Sunline T24 Saturn 25' TT (Pics) - Every option avail at the time.
OK, making it even simpler...when it snows in a couple months do I just turn the inside switch to 4HI. Do I have to even worry about locking the hubs manually on the wheels?? What about switching to 4Low...I'm guessing I have to be stopped in P or N with foot on brake? Do I need to back up when switching out of 4Low? I just want to be educated on the proper operation of my 4X4 so I don't break anything and have to pay repairs for stupidity.
As long as the hubs are in the auto position just flipping to 4HI puts you in 4x4. 4LO requires you to stop, be in neutral, break on (I think) and then switch to 4LO. Taking it out of 4LO requires you to be stopped, in neutral, and flip the switch back to 2WD
It is auto 100% by flipping the switch. The locks are for serious 4 wheeling. With autos the wheels have to slip to engage, sometimes too late, the lock makes sure going in you are in 4 wheel. Make sure you turn them once a month, they will stick and you will need big pliers to move them. Otherwise the auto is nice, I use 4wlo to pull my boat out, you need to hit the brake to get it out also. [img]/ubbthreads/images/graemlins/cool.gif[/img]
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium.http://community.webshots.com/user/stellinm
If you want to really make sure the 4 wheel drive is engaged, I would lock hubs in manually. I have fixed auto feature 3 times. I will eventually switch to Warn manual hubs. The light on dash does not mean hubs are locked. Which means I usually have to get out and lock hubs to get up driveway after snowstorm or break out snowblower.
I disagree with the slip to engage part, this system doesn't work that way (unless you have something different). I have 2HI / 4HI / 4LO. You can switch from 2HI to 4HI while moving at speeds less than 25mph. I generally leave my hubs manually locked all winter & switch to & from 4Hi at any speed. Some will say this practice is a bad idea, I say maybe.
John M, Do you have to back up a bit to disengage the hubs.I make it a habit to back 50' to disengage the hubs. Maybe I'm wasting my time.
[/ QUOTE ] Nope, backing up will generally unload the driveline & allow the hubs to unlock. It's a good idea you keep doing it.
DDD
__________________ My Photos----- BTS BUBBA "Life Member"
2002 7.3L Excursion 4x4, FTVB, MBRP 4" SS Exhaust, Rancho 9000X shocks, "V" code Front Springs & "B" Code Rear Springs, Ride Rite AirBags, Rear Hellwig Swaybar, Cut Front BumpStops, DieselSite Ext Trans Filter Kit - Coolant Filter Kit & 203 stat, "Scotpart" mod, "Hutched & Pooned", "LandYot" Radius Rods US Gear Overdrive 75mph @ 1750rpm's
2001 7.3L F350 CC LB 4x4 5" Exhaust, pillar guages, BTS Trans, US Gear Underdrive, DP 6 pos chip, V10 Trans Cooler, DieselSite - Coolant Filter Kit, Evans Coolant, 203 stat, DI reg Fuel Return, GT38R BB Turbo, AFE 2 Intake, Banks Intercooler, Air Rite Bags,
2000 Excursion Limited V10 4x4 7" Lift
According to the manual, that little book that came with the new X, , ,
The auto lock works when the wheels can move and allow a lock to take place. IF you are already stuck then the auto very likely will not engage so the manual allows you to go to 4x4 if you can reach the hub.
Not that I read manuals, but I was looking for pics and just happened to see that note. : ))
mesu
Excursion 2004 4X4 Limited - PUEBLO GOLD - 6.0L T-C Diesel - 5-Spd Auto Trans -AM/FM Sterio In-Dash 6-CD - Rear Seat Entertainment - DVD - 2nd Row -Dual Bucket Seats - PWR HTD T-T Mirrors - 3.73LS Axle - T-Case Skid Plate - Thule Top Rack - SC Tuner
Veh. Built 7/16/03 Eng. Build date 6/27/03 by International - Purchase Date 9/1/03 Milage on date 6/9/04 = 15,000 11/15/04 = 26,890 4/19/05 = 35,639 12/12/05 = 49,810 8/29/06 = 63,750 3/27/08= 100,003 Rancho 9000 shocks F & R.
It is hard to take travel serious when every time you leave home you take an Excursion !
