Old 04-13-2005, 05:01 AM   #1 (permalink)
wow
Sub-woofer in rear doors?
When we bought the X one of the first things I thought of when I saw those rear doors is that they would make a great place to mount a sub-woofer. Has anyone done this? If so, did you build an enclosure or line it with dynamat or what?
Thanks in advance for comments or pictures!
Wayne
2004 X Limited. Medium Gray Metallic, 4x4, 6.0L Diesel, DVD, LimitedSlip Differential, HD Tow Group, Transfer Case Skid Plate, Radius Rods, Remote Starter, Magnum Hitch, Nitto Terra-Graplers, Running Boards Removed, Large Payments.
wow is offline
Old 04-13-2005, 11:27 AM   #2 (permalink)
FamilyRide's Avatar
Re: Sub-woofer in rear doors?
Do a search and you'll find a member (sorry, can't remember who it is, and he's right here in the DFW area too!) who has someone that built a custom rear door enclosure.
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 04-13-2005, 03:13 PM   #3 (permalink)
I have done this on the driver side door. Here's what we did, more or less.
1. Remove plastic/carpet trim panel thing.
2. Measure the void you'll need in the interior-facing part of the door. You will need to cut this material away. The door is fiberglass so this is easy.
3. We then fabbed up a sheet of plywood that the sub actually bolts to. The plywood then in turn is bolted to the fiberglass door. We tried just attaching to the fiberglass but it flexed too much. This wooden panel also has a number of holes cut in it with a holesaw so the plastic trim thing will still line up with the factory fasteners. This more or less works like a champ (more on the "less" part in a bit)
4. Before buttoning everything up, line the back with Dynamat and check for clearance. When shopping for your subs, try to get one that is relatively shallow in depth. If it's too deep the magnet will rub against the back side of the door. I put a 10" JBL in mine and with the wood panel in place, I barely don't rub.
5. Re-attach trim thing. In its current configuration like this, the trim thing is going to vibrate when you use the sub and be annoying. I fixed this for the most part by...
6. Get a screw-in, clamp-down speaker grille. The kind with the four clippy things that you screw into a sub box and in so doing clamp the grille down onto the enclosure. In our case we are effectively screwing the plastic trim thing down into the wooden panel we fabricated, which goes a LONG way toward silencing annoying vibrations. Some dynamat between the plastic and wood would probably silence the thing entirely.
So far I'm happy with my simple implemtation. It makes plenty of bass for what I listen to, looks nearly factory, and didn't involve days worth of fabrication. The "subs in the cargo doors" thing is great for people like me who want some bass, but bought an Excursion because of its vast storage space. Taking up some of that space with a speaker box was something I didn't want to do.
We did snap some pictures but it's unlikely that I'll find them, as it's been about a year now since we first started working on it. If I find them I'll post them up.
Karl in NC
2001 Excursion Limited: exhaust, rear sway, Bilsteins
1995 Integra GS-R ITS/H3 race car for sale
SOLD: 99 Suburban, 98 trailer, 95 Integra, 90 CRX Si, 87 BMW, 73 MGB
krshultz is offline
Old 04-13-2005, 04:09 PM   #4 (permalink)
BenBone's Avatar
A JL stealhbox takes up no room also...if your trying to save space and the enclosure is designed exactly for the specific model speaker.
2004 6.0l 4WD Limted Excursion
Road Armor Stealth Bumper with Titan Guard, BFG AT 305's, AR Mojave Teflon's, Tint, Stereo, Remote Start Alarm, Strobes,MBRP Turbo Back T-409 Stainless Steel Exhaust System, AFE Pro Guard 7 Mega System, Edge Insight, Coolant Filter, ARP Studs, Hybrid Turbo, EGR delete
http://bbonepics.shutterfly.com/
1999 Ford F250 CC LB 4x4 7.3L
DP F5, MBRP 4", AFE Satge II,Garrett Power Max Ball-Bearing Turbo,80hp injectors DM 3 pod, 95 Gallon Transfer/Toolbox Chest, BGF AT 295's, AR Mojave Teflon's,Tint, Road Armor Stealth Base Front Bumper with Lonestar Guard
BenBone is offline
Old 04-13-2005, 06:45 PM   #5 (permalink)
Does the Stealthbox go in the center console (same as in the SuperDuties)? I am considering it, too.
Len
2002 Excursion PSD Limited, 4X4, Aspen Green, Cortex Tuner, Walker BTM, A pillar gauges, Bilstein shocks, Ford finned diff cover, Hellwig Sway Bar, and BFG LT285/75R16E tires.
coldpizza is offline
Old 04-13-2005, 09:59 PM   #6 (permalink)
Len
Yes - same box.
I saw the Alpine factory show X at a local event ... had 8 speakers in each front door ...
04 Excursion Limited 6.0 PSD 4x2
02 Honda S2000
Cheetah DSR
Jaysom is offline
Old 04-15-2005, 01:20 PM   #7 (permalink)
Can anyone find the stealthbox online and throw in a link here? I have searched forever and I never seem to find the one for the Excursion. How much are they?
I have 2, 12" Rockford Fosgates in a box, but I am tired of it taking up the room.
Sam Hinton
SHINTON is offline
Old 04-16-2005, 02:07 AM   #8 (permalink)
BenBone's Avatar
http://www.jlaudio.com/stealthbox/excursion.html
BenBone is offline
Old 04-16-2005, 10:13 PM   #9 (permalink)
The optimal cabinet for a sub is concrete (we all know that isn't practical for most applications). The doors are fiberglass and plastic. That would require some serious reinforcement, and I don't think the hinges could handle it.
You could do it, but it wouldn't be worth the $$$
I would find a sub that dosen't require much air space and build a cabinet with a quick-release connection for when you need to fill your cab with stuff.
If the cabinet that replaces the console sounds good, that would be your best bet. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
KwikStix
2000 PSD Excursion Limited 2WD, 150+K miles, Chestnut, Medium Parchment Leather, Limited Slip 3:73, BTS Tranny, Diesel Innovations 4-Way (Valet-Tow-Crazy-Stupid Fast), AutoMeter Carbon Fiber Gauges(boost,pyro,tranny), AFE Stage 1 intake, Magnaflow 4" down to 5" Stainless tip, Whicked Wheel, HX Crossover, KYB's, Hellwig rear sway, Michelin 285's
kwikstix is offline
Old 04-17-2005, 12:21 AM   #10 (permalink)
i am also wanting to this. put the sub in the rear doors. i was shopping around and a few guys told me that they have put those square subs (forget the brand) in the rear doors of an X. they had to build out the doors with wood so the magnet would not rub in the back. i have seen some pics of on the net awhile ago. i will try to find it. ill post it when i do.
Sukhi
2000 Ford Excursion 4x4 7.3l Powerstroke Diesel.
8" Edge suspension lift. Donahoe Racing Res. shocks. Deaver Leaf springs. Fabteck 3.5" hangers. Mickey Thompson 38x15.50r20 MTZ's. 20x10 Jesse James Lawless 8 rims, AFE Stage 2 intake. Auto-meter guages: pyro, trans, boost. ART slotted rotors, performance friction pads. 4" turbo back SS straght pipe exhaust(no muffler), DP-Tuner 4 pos flip chip 80/100/120/140, Billet grill, Apc Projector head lamps. Clear corners, AMP Research power steps.
my other trucks
1997 GMC Suburban 4x4 6.5l Turbo Diesel.
1996 Dodge Ram 2x4 5.9l Cummins Diesel.
1997 Chevrolet Tahoe 4x4 6.5l Turbo Diesel.
1990 Ford Club Wagon Van 2x4 7.3l Diesel
1989 Chevrolet 1ton Van 6.2l Diesel.
2003 Chevrolet C4500 6.6l Duramax Diesel/Alison
powerstrokex is offline
Old 04-17-2005, 07:23 PM   #11 (permalink)
Sam Hinton
I think I paid around $450'ish ... the box does come with the 10" sub installed.
02 Honda S2000
Cheetah DSR
Jaysom is offline
Old 04-19-2005, 07:03 PM   #12 (permalink)
I have an Alpine sub mounted in each of my rear cargo doors. Here are pics:
http://www.fordexcursions.com/vehicl...=12984#content
I would highly recommend building an enclosure if you want it to last. The rear doors on my X were just lined with dynomat and we also inserted that cotton/stuffing into the doors to give it the effect of being a larger box. After 4 years, the front panels are coming off and it's time for a re-design...definitely need an enclosure this time around.
The hinges have held up quite nicely.
-Eric
'67 Galaxie Pics | '00 Excursion Pics
erlong is offline
Old 04-21-2005, 10:29 AM   #13 (permalink)
Couldn't you just mount them behind the plastic door panels,without making any cut outs in the plastic? The sub's should just be for base. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
My Photos
<font color="red">2002 EXCURSION, PSD, XLT Premium, 4X4, Medium Wedgewood Blue,8' Meyers E-Z Mount Snow Plow,14.1" rear LCD video monitor and DVD, FS2500 bypass oil filter, Mobile 1 synthetic ATF, Rotella T 5w-40 synthetic oil, Baldwin transmission filter, K&N filter charger with Zoodad mod., Banks Trans Command, Bilstein shocks, Rancho steering stabilizer, Hellwig rear anti-sway, XM Commander satellite radio, C-Bet'r convex mirrors, factory remote start, daytime running lights, Silverstar headlamps, "Xtra" reverse lights, Hidden Hitch front hitch receiver.Cabela's Winter Grill Cover by Fria</font>
1996 Ford Crown Victora P-71, white, blue cloth buckets, super clean and super fast.
2006 Subaru Forester 2.5X Premium(I highly recommend it in snowcountry)
2005 Gulf Stream Canyon Trail 29TEBH,with Reese D/C HP
JOE_M is offline
Old 04-21-2005, 03:18 PM   #14 (permalink)
TXANGLER on here was working on having more of the door panels made like he has in his X. Haven't heard of anything lately though.
2002 Limited Ultimate Premier No Boundries Excursion 7.3l 4X4 all black with every option Ford could come up with. X-code F550 front springs, full size leaf added in the rear, 265 Bridgestone Dueler Revos, Edge Juice with Attitude, Edge Evolution, Autometer sport comp guages, IDM mod, Walker BTM muffler, SPDiesel exhaust brake with t/c lock up control, Catch-All floor mats.
edunn69 is offline
Old 04-21-2005, 04:21 PM   #15 (permalink)
There's not enough room, at least in my install there wasn't. The speaker is too "deep" and hit up against the outer wall of the door.
Karl in NC
krshultz is offline
