Suspension - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 10-22-2009, 02:02 PM   #1 (permalink)
Suspension
Is this what I need?
Hellwig Anti-Sway Bars Sway Bar - Rear - 1 1 - 4 in. Diameter - Steel - Black - Ford - F-250 - F-350 Super Duty Pickup - Kit | StreetPerformance.com
I have the RS9000s ready to add and want the sway as well. The currently is no sway bar at all. I have to find a kit with the included hardware.
gager2002 is offline
Old 10-22-2009, 05:57 PM   #2 (permalink)
We need to know what little about your truck
Like year and so on
There are more options on latter years
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Just about finished!(never tell the wife you are done)
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 10-22-2009, 07:44 PM   #3 (permalink)
boomboom's Avatar
I believe an Excursion frame is differant width then truck frame. Hellwig rear sway bar kit part # 7643 is for Excursion 2x4 and 4x4. It is differant from truck part #'s . I'M ASSuming you have an excursion sense you posted on Excursion thread
boomboom is offline
Old 10-23-2009, 08:52 AM   #4 (permalink)
Sorry, guys.
Yes, 2003 Ex PSD, 4X2.
Old 10-23-2009, 10:55 AM   #5 (permalink)
Send a message via Yahoo to keith_1963
I have been advised the Ford heavy duty sway bar is better, at half the price. I believe its a 30mm sway bar.
2001 Excursion Limited. Tymar air filter. Marineco Mod, Oil change ball valve. FOR SALE.
keith_1963 is offline
Old 10-23-2009, 03:16 PM   #6 (permalink)
I agree with you. BUT, my 4x2 Excursion has never had any bar installed. I will go to the dealer to get the parts, butI need to know exactly what I need to install it on the truck. Is it a bolt-on. Nuts, bolts, washers, and bar? Or is it drilling the truck anywhere?
Old 10-23-2009, 05:39 PM   #7 (permalink)
i havent check the oe bar price and would question whether or not it is better than the helwig. Both mount with no drilling. The helwig is under $200 shipped and is larger in diameter than the 30mm OE part. Bruce1954 I think has used both so maybe he can chime in.
2001 X, 4x4, White, Limited, PSD,. Oil Guard, Stull 6099 Grille, AFE Intake, X Monitor, Sonnax/Tricumulator, Mobil 1 ATF w/Racor tranny filter, PHP Custom Burn Chip, Walker BTM, W Code Frt Springs, Procomp Add-a-Leaf Rear, Rancho 9000XL's w/5406 SS. Pics @ http://community.webshots.com/user/txangler32
TXANGLER is offline
Old 10-24-2009, 04:00 AM   #8 (permalink)
boomboom's Avatar
you could try to send caryt a pm and ask him. I think he might have ford part #s your looking for. Make sure you tell him you have a Excursion.
boomboom is offline
Old 10-24-2009, 08:28 PM   #9 (permalink)
I am sure the ford bar can be used and I highly recommend it over the Helwig bar.
I was one of the first to install a 30 MM bar on my 02 X you can see the pictures in my signature.
Back then I had to make the link arms but you can use all the parts from the 04/05 X.
The only question is if the right rear shock plate would have to be replaced or modified as I did, it can be seen in the pictures. The 03s had a few running changes and you have 2WD most here have 4X4s so we are even less sure. Take a look at my old pictures they should help.
It can be all bolt on the question is the right shock plate.
Let me know if you have any questions.
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
Old 11-05-2009, 05:41 PM   #10 (permalink)
I have been advised the Ford heavy duty sway bar is better ...
I agree with that statement, and I've had both. I installed a Hellwig rear anti-swaybar on my '01 Ltd 4WD, and my '05 EB 4WD came with OEM rear anti-swaybar. I prefer the OEM bar's performance.
Hoowasat is offline
Old 11-06-2009, 10:11 AM   #11 (permalink)
Feedback Score: 3 reviews
Hit the junk yards or local 4x4 shops find any size bar and brackets from a SD then if its not the 30mm order one..$100+-.
Cary
caryt is offline
Old 11-06-2009, 10:21 AM   #12 (permalink)
Good idea. Junk yard hunting tomorrow.
