Old 01-09-2005, 08:53 PM   #1 (permalink)
Suspension mods. for Excursion for towing
I'm new to the board. Owned three different Ford F250s over the past several years. Haul a boat throughout the year, except during these rainy months here in No. CA. Total estimated weight of boat/trailer/gear etc. is about 6,000#+. I have given up my trucks for a 2001 Excursion Limited, with 7.3L PSD (family growing, looking for more comfort, etc. as I get older). Looking for advice on mods. needed ford the suspension etc. in order to pull by boat without any worries. I'm not concerned with the X's ability to pull the load, it's the suspension that concerns me. I already know that I need to go to a WD trailer hitch set up, since dead weight max. on the X's stock hitch is 5,000#. I'm thinking of adding a Hellwig swaybar and maybe air bags. I'm not looking for anything radical (X is all stock), plus I commute over two hours (RT) each day in it, I just want to make sure that I can haul with confidence. Any thoughts from other X owners.
Thanks.
Paul
potis is offline
Old 01-09-2005, 09:29 PM   #2 (permalink)
Re: Suspension mods. for Excursion for towing
HD shocks (of your choice);
and
Hellwig sway bar;
and (your choice):
air bags, or
Timbrens (front and rear)
www.timbren.com
jschira is offline
Old 01-09-2005, 09:55 PM   #3 (permalink)
Check my sig..Mine tows like a champ with what I have.
My Photos
<font color="red">2002 EXCURSION, PSD, XLT Premium, 4X4, Medium Wedgewood Blue,8' Meyers E-Z Mount Snow Plow,14.1" rear LCD video monitor and DVD, FS2500 bypass oil filter, Mobile 1 synthetic ATF, Rotella T 5w-40 synthetic oil, Baldwin transmission filter, K&N filter charger with Zoodad mod., Banks Trans Command, Bilstein shocks, Rancho steering stabilizer, Hellwig rear anti-sway, XM Commander satellite radio, C-Bet'r convex mirrors, factory remote start, daytime running lights, Silverstar headlamps, "Xtra" reverse lights, Hidden Hitch front hitch receiver.Cabela's Winter Grill Cover by Fria</font>
1996 Ford Crown Victora P-71, white, blue cloth buckets, super clean and super fast.
2006 Subaru Forester 2.5X Premium(I highly recommend it in snowcountry)
2005 Gulf Stream Canyon Trail 29TEBH,with Reese D/C HP
JOE_M is offline
Old 01-09-2005, 10:44 PM   #4 (permalink)
mike650's Avatar
Don't think; please get a rear swaybar, Hellwig or Ford 30mm. This should be mandatory with an Excursion, towing or not.
Upgrade the shocks to a heavy duty shock like Bilstein, Rancho, Monroe, Edelbrock, etc.
Here are some additional suggestions to make your X handle and perform really well:
Upgrade the front springs to Ford F250 "u" or "v" codes and replace the front bump-stops with 2003 Ford Excursion bump-stops.
If you are towing a lot of weight look into airbags. I can not give a recommendation because I do not have any...yet.
Upgrade the OEM front steering stabilzer bar to Rancho, Procomp, etc.
If stock, upgrade the tires to 285/75/16's.
Good luck,
-Mike
2002 Excursion ~ Limited Ultimate ~ 7.3L PSD ~ 4x4
Mineral Gray, Limited Premier Group & Monochrome Package, two tone leather interior (pre-Eddie Bauer), TTT Mirrors, 3.73 Limited Slip, F250 Lariat wheels.
Kentucky Born: 4/9/2002
Improvements: 2002 PSD Badges, and lot's more!!
mike650 is offline
Old 01-09-2005, 11:34 PM   #5 (permalink)
FamilyRide's Avatar
6000 lbs???? If you don't have a rear antisway bar, get one.
Otherwise, 6000 lbs for a boat that is set up properly and on a good tandem axle trailer with brakes is nothing just the way it sits (with a rear bar of course).
All the rest might make it better, but it's overkill for 6000 lb boat set up on the right trailer.
Notice I keep going to the trailer and how it's set up? [img]/ubbthreads/images/graemlins/laugh.gif[/img] If the trailer was not set up for that boat specificly, that could be a problem that nothing else will help with. [img]/ubbthreads/images/graemlins/wink.gif[/img]
BTW, mine's about 7500# and I DO have the OEM rear bar but that's it. Could it be better, sure, it could always be better. Better shocks might help but it's fine the way it is now.
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 01-10-2005, 07:03 AM   #6 (permalink)
Here's what I've done. Very little actually.
I tow a 24' enclosed car hauler (trailer's GVWR 9,900$).
I've had to do very little, but I do use a WD hitch, and the best mod I ever made was the addition of the Ride Rite air springs!!!
That's it.
Truck rides just fine as far as I'm concerned. Never felt or saw the need for a hellwig or otherwise yet.
TurboDave, EWCS(SW)USN Ret
H&N Turbo 6 Racing
Seviervile TN
A MAN AND HIS TRUCK, IT'S A BEATUFUL THING
01 Excursion LTD (EBM3) 7.3L, PSD, Turbo, 4X2, TTS Race Magnum (original owner)
86 GN (original owner)
87 GN (second owner)
08 Honda Accord EX-L
My Photo Gallery
turbodave is offline
Old 01-10-2005, 07:58 AM   #7 (permalink)
Do it and see what you have been missing.
jschira is offline
Old 01-10-2005, 11:04 AM   #8 (permalink)
CHPMustang's Avatar
It was night and day in comparison going from stock to our Excursion upgraded with a Rear Swaybar,Shocks and steering stabilizer [img]/ubbthreads/images/graemlins/cool.gif[/img]
Bill
2002 Ford Excursion 7.3L 4x4 XLT
9th Annual Powerstroke Rally this Oct 3-5 2008 in Caddo Mills,Texas
CLICK HERE for more Information & Register Here
CHPMustang is offline
Old 01-10-2005, 11:52 AM   #9 (permalink)
Thanks everyone for the suggestions.
Joe_M - What is the weight that you are towing. I noticed from you sig. that you did not add air bags, change springs etc.
FamilyRide, Your points are very valid and important. My boat and trailer combo is set fine. I have owned it for over 4 years and pulled it with two different trucks (a 1997 F250HD PSD 4x4 and 2001 F250SD PSD 4x4). The load has always seemed to be distributed perfectly - never the slightest problem.
Paul
potis is offline
Old 01-10-2005, 05:22 PM   #10 (permalink)
Well, as I stated, I'm happy with the ride performance. After all, I do realize and take into account that I'm driving an 8,000# truck, and not trying to treat it like a 2,000# sports car. Trust me, I've seen a LOT of guys trying to drive their X's and SD's like a sports car. [img]/ubbthreads/images/graemlins/frown.gif[/img]
Maybe my Ride Rite springs are making a huge difference. Don't know. They sure made towing a dream.
H&N Turbo 6 Racing
Seviervile TN
My Photo Gallery
Old 01-10-2005, 06:30 PM   #11 (permalink)
Paul
1. See my Bio
2. Forget Timbrens for front unless you are installing a snow plow
See posts by Pharmer he has had both springs and Timbrens
3. Note that TurboDave has a 4x2 Different Front end and no relation to a 4X4
Bruce (AKA the spring Info Guy)
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 01-10-2005, 07:08 PM   #12 (permalink)
FamilyRide's Avatar
In most cases that's the deal and I assumed you were good as well. Unless someone tries real hard to mess one up, boat and boat trailers on Tandem axle are balanced perfectly. Got to a TT that's 2000 lbs lighter and you'd have more challange and really need to show your towing and tow equipment smarts. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
OT but what kind of boat do you have??
Old 01-10-2005, 09:41 PM   #13 (permalink)
My Photos: (20)
I installed Air Lifts in the rear and Bilsteins F&amp;R on my 2000 4x4 PSD Excursion and it towed my 41 ft TT like a champ. I have F&amp;R Air Lifts and a rear Hellwig SB that I plan on installing on my 2003 this spring.
jogiba is offline
Old 01-10-2005, 11:02 PM   #14 (permalink)
My 2003 and 2004 have rear sway bars installed from the factory. I tow slightly smaller 31 ft with slide all over the US (over 10K last year) and stock works just fine. I added all the goodies to my 2001 and not much improvement just a harder ride and poorer (money spent).
I would add the rear sway bar to the 2001 though, and that is about it.
2004 Ford Excursion 4x4 Eddie Bauer 04 6.0L B/D 10/24/03
2001 TrailBay 31BHSS W/Slideout
1964 Karmann Ghia Coupe
AXTINC is offline
Old 01-16-2005, 01:19 AM   #15 (permalink)
As you’re finding out, the stock Excursion suspension is a bit soft for towing. So far, I’ve changed the front springs to “X” codes with F-350 blocks on the rear, Edlebrock shocks, Firestone rear air bags, Hellweg front &amp; rear sway bars, Rancho steering stabilizer, Toyo M55 285/75 tires, and a Detroit locking rear differential.
Christmas of 2003, we loaded up the Excursion with gear, guns, ammo, and then hooked up a flatbed trailer with an 84 F-250 SC 4x4 on it with a Polaris Sportsman 700 in the bed of the pickup. The whole rig weighed in at 19,440 pounds with 1/4 tank of fuel and four adults. The Excursion handled GREAT! We drove through the mountains from Casper, WY, to Yuma, AZ, and drove the posted speed limit to +5, except when passing slower traffic. The rig seemed a bit heavy on the trip so we pulled into Barney’s Truck Stop in Yuma and onto the Cat Scales. I was more than a bit surprised to see the weight ticket of 19,440 pounds. In my opinion, the suspension mods are well worth the money! [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
00 Excursion Limited, Detroit Locker, (rear), X code front springs & f-350 rear blocks, Edlebrock Shocks, Firestone Air Bags, (rear), Helweg Anti-Sway Bars, (front & rear), Rancho Steering Stabilizer, BFG A/T 285's.
OB-1 is offline
