Old 09-20-2000, 04:27 AM   #1 (permalink)
Suspension Parts
Any thoughts on dealers with the best prices on the new Edelbrocks shocks and Hellig anti-sway bars(in stock)? Does Rancho stearing stabilizer really help?
I'm posting a familiarity question on the main PSD board about Eco-Clean oil filters. Good, bad, indifferent. If you use one or know about them please drop me a line. Thanks.
2000 Excursion..loaded...and still being loaded [img]/ubbthreads/images/graemlins/smile.gif[/img]
http://www.albums.photopoint.com/j/A...238&a=10085914
IMDOK is offline
Old 09-20-2000, 09:56 AM   #2 (permalink)
Re: Suspension Parts
IMDOK,
I did a search trying to locate shocks for my X and found the best price on the IAS Edelbrocks at one of the sponsers on the site, go to http://www.superdutyheadquarters.com
I checked eshocks and shock warehouse, could meet the pricing but come on some no name internet warehouse. Keep your business here when possible. As to your other requests I am unable to help, although I will be waiting to hear about the hellwig stabilizers!!!
Dave
'00 Excursion XLT 4X4 PSD 3.73LS Superchips 50/100, K&N,lighted running boards, overhead console, leather, cd/6 cd changer, DEI Python 1500 w/remote start and shutdown timer.
'00 Excursion XLT 4X4 PSD 3.73LS, ATS 4R100 w/TripleLok TC, AFE, Edelbrock IAS, Hellwig Front & Rear sway,Rancho RS5000 SS, SPA Dual gauge EGT/Boost dash mtd, 4" exhaust w/Walker Big Truck muffler
excurstroked is offline
Old 09-20-2000, 01:22 PM   #3 (permalink)
I ordered a Pro-comp steering stablizer from SDH. Its supposed to be a direct replacement for the stock part. I'm hoping that this will control some of the lateral movement ovr big bumps and decrease the movement in the steering wheel I feel on some roads. I can't justify the shocks until at least 20k miles. Has anybody put Goodyear 305/70/16 on a stock Excursion rim. If so did this improve the ride.
xr7gt is offline
Old 09-20-2000, 08:54 PM   #4 (permalink)
carparts.com has the Edelbrock IAS's for 66.14 apiece, and will give you 15% off a first time order. This is the best price I've found.
I rec'd mine on monday, and plan to install them tommorrow.
2000 Ford Excursion XLT 2WD, Chestnut/Parchment, V10, 3.73ls, autolamps/DRL's, Rear air deflector, Banks Powerpack with Transcommand, Edelbrock I.A.S's, 1 steel rear lift blocks, Tekonsha Sentinal. Towing a '00 Holiday Rambler 31 SKS, 10K gvwr
3992824 is offline
Old 09-21-2000, 02:47 AM   #5 (permalink)
IMDOK,
Yes the Rancho steering stabilizer helps. I was pleased with mine as it made the steering much smoother. I don't believe it makes much if any difference with the sway issue. My 350 came through with no steeing damper. I put the OEM X damper on the 350. The X is much better with the Rancho.
If you can get the right coupon code from carparts.com you will get 1/3 off the list price of 74.95. Works out to $50 each for four shocks, pre-shipping. You will need to do a search to come up with the current discount code.
My Edelbrocks arrived today for the F350. They are going on this weeekend.
I understand Hellwig was designing a rear stabilizer for the X and I believe ExcursuionPSD posted a part number. I have not seen it available anywhere on the net yet. Will order one as soon as I see it.
2000 Excursion LTD 4x4, Oxford White, PSD 3.73, K&N, Hypertech PPIII, Dynomax Muffler, Ramsey Winch Mount & Grill/Brush Guard, Edelbrock Shocks, Rancho Stabilizer, PIAA 90 PRO XT Lights, 295 BFG's, 2000 F350 CC PSD 4x4 Woodland Green, 3.73 K&N, PPIII, 295 BFG's
2000 Excursion LTD 4x4, Oxford White, PSD 3.73,K&N, PPIII, Dynomax, Ramsey Winch Mount/Grill/Brush Guard, Edelbrocks, Rancho SS, Hellwig Stabilizer, PIAA 90 PRO XT Lights, 295 BFG's, X springs, 2000 F350 CC PSD 4x4 Woodland Green, 3.73 K&N, PPIII, 295 BFG's, Edelbrocks
POLR BR is offline
Old 09-21-2000, 04:37 PM   #6 (permalink)
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by POLR BR:
IMDOK,
...If you can get the right coupon code from carparts.com you will get 1/3 off the list price of 74.95. Works out to $50 each for four shocks, pre-shipping. You will need to do a search to come up with the current discount code.
<HR></BLOCKQUOTE>
Fall is a great time to go for an Excursion! Everyone around town is very excited over the Packers crushing 6-3 victory, they now have only lost 2 games out of their first 3.
Hellwig rear sway bar #7643, is $130 incl. freight from summit, it is available now, you may have to ask.
I think I saw you guys at the NASCAR race, try to look for your coupon from carparts.com/gift for 1/3 off up to $100 by 3/31/01 it is the one with code 1963005 on it.
You might also see if you can get a good deal on the whole combo from SuperdutyHeadquarters.com, one of our sponsors.
The Edelbrock IAS shocks for V10/PSD are
Excursion 4x2
front-rear 33225-34225
Excursion 4x4
front-rear 33224-34224
Remember, they install opposite of normal shocks: The Edelbrock Inertia Active Shock (IAS) needs the inertia modified valving on the rod to feel the action coming from the wheel, so rod end on the axle, monotube body attached to the frame!
note to AJ'sDad who might post something after me...
Whenever I buy a pencil I tear the eraser off, since I don't make mistakes
2000 Excursion Limited born 11/99 4x4 Toreador Red ext./gray int. 7.3PSD, 3.73LS, Skidplates, Pwr/Htd TeleMirrors, 6CDchanger, HtdBuckets, LT265/75R16D AT, Ford Wraparound deflector, PSDV8 badging, RoofMarkerLights, Tekonsha Sentinel brake cntrlr
[This message has been edited by ExcursionPSD (edited 09-22-2000).]
2000 Excursion Limited born 11/99 4x4 Toreador Red ext./gray int. 7.3PSD, 3.73LS, Skidplates, Pwr/Htd TeleMirrors, 6CDchanger, HtdBuckets, LT265/75R16E Bridgestone Dueler A/T Revo, Ford Wraparound deflector, PSDV8 badging, RoofMarkerLights, Tekonsha Sentinel brake cntrlr, PCM=AXD0, Edge Evolution II, WalkerBigTruck Muffler, RS9000, RS5410, Performance Friction 2 piece rotors/pads, Sylvania SilverStars, Landyot Gen III, Air Lift rear air bag system, Amsoil from MAXoil.com in diffs/trans/transfer 251k miles.
ExcursionPSD is offline
Old 09-22-2000, 05:16 PM   #7 (permalink)
Excursion PSD,
Don't you mean that they install with the body up and the rod on the bottom? It's my understanding that Edelbrocks installed the opposite of regular shocks.
2001 Black Excursion, 4x4, XLT, PSD, LS, (EBM2), Super-Duty grill, 4" MBRP exhaust, Bilsteins, X-springs, OilGuard bypass filter, 295's, Badges, Suvlights harness, APC headlights, Weatherboots, Centramatics, Clear corners, AIC w/ITP mount, ISSPRO EVs, BTS trans, Open element intake, ATS compressor housing, Thule rack, BD Torqloc, F350 rear blocks, Randy Ellis lightbar with a couple of Lightforce 170s, Front receiver hitch, DP Tuner chip
1975 Ford Bronco, neglected since I bought the Excursion
AJ'sDad is offline
Old 09-22-2000, 09:09 PM   #8 (permalink)
My Photos: (20)
I thought Edelbrock had a differant part number for the front shock on 4x4 PSD models than the v10. Someone on this forum even let them use his PSD Excursion to design it.Also is the Ford rear sway bar on F250/350 SD pickups with camper option the same dimensions as the Excursion aftermarket swaybar ?
jogiba is offline
