Old 01-14-2006, 11:53 AM   #1 (permalink)
Swapping to a taller rear block?
Is this as easy as just jacking up the truck and swapping the stock 2 inch to the taller 4 inch block? I don't like how these sit level unloaded, seems like any kind of load is gonna make it sqwat pretty good, so I figure just putting in a taller block will get me where I want to be. How easy is this? U-bolts long enough?
WhiteSuperDuty is offline
Old 01-14-2006, 09:39 PM   #2 (permalink)
Re: Swapping to a taller rear block?
You need the longer U-bolts. The stock ones would barely make it, I don't think you would have 1 thread above the nut... in any event, most recommend replacing the U-bolts instead of re-using them.
06 F250 Crew Cab LB V-10 4x4
99-122 Bright Atlantic Blue S-281 S/C Convertible
Factory Five Daytona Coupe #139
tfalk is offline
Old 01-15-2006, 10:20 AM   #3 (permalink)
Make sure to get the tapered blocks or you will have drive line vibrations. You will need the longer U bolts to install them correctly.
FMT
Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
Old 01-15-2006, 09:55 PM   #4 (permalink)
If you want the 3.5 - 3.75 inch tapered blocks for an F350, the part
numbers are F81Z-5598-FA and F81Z-5598-GA.
tfalk is offline
Old 01-16-2006, 02:37 AM   #5 (permalink)
So the factory blocks from the 350's are either 3.5 or 3.75 inches tall?
I've got 6" front springs and 5" rear springs for my X. So it sound like I can just swap in an 350 stock block and make up the difference? Does that sound right?
A1980GMC is offline
Old 02-03-2006, 04:01 PM   #6 (permalink)
My Photos: (27)
When I swapped my factory blocks for F-350 blocks the one ton blocks measured 3 3/4". My factory X blocks where not 2" (1 3/4") but 3" (2 3/4"). It messed me all up. I knew there was a 2" difference in the blocks between an F-250 & F-350. So, after I replaced the front springs on my X, I was 2" low in the rear. I thought switching out the blocks for F-350 blks would do the trick. I never thought to measure the X rear blocks. Once I put the F-350 blocks on and set the truck down, it sat 1" low in the rear. [img]/ubbthreads/images/graemlins/shrug.gif[/img] I ended up bolting a 1" spacer block to the spring pack to finally get my level stance. I don't know if this X was unusual or if more X's have this funky size rear block. For those of you doing this, you may want to measure your block first.
Take Care,
Lane
2008 F-350 Lariat, 6.4 PSD, 4x4 Dually
Tow Boss, 4:30 gears, 450 wide track, 6" Pro Comp radius arm lift, MX6 reservoir shocks, 22" American Force dually whls, 37" Toyo MT's, Buckstop bumper w/Warn 16.5, APM Ram air hood.
North Texas Power Stroke Association & Wyoming Power Stroke Association
BadSuperduty is offline
