Sway bar - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 10-04-2003, 04:49 AM   #1 (permalink)
Sway bar
I apologize for posting this question. I know it has been talked about many times. I did a search anc could not find the information I was looking for. I want to know plan and simple, do I have a sway bar on my truck, if not, should I get one? I am talking one the is mounted on the truck, not the one on the hitch for towing. I do tow some, but I am hoping for better handleing on the truck. Also, if the answer is I should get one, where can I go and how much does it cost? Thanks for your help.
03" Black X Limited with a 7.3 PSD
Boston is offline
Old 10-04-2003, 08:45 AM   #2 (permalink)
Re: Sway bar
No. All 7.3's were made before November 2002. Ford (in its infinite wisdom) did not installing rear sway bars until about March 2003. Also, you do not say, but no 4x2 came with the rear bar. You do have a front sway bar.
Yes. Definitely.
Summit Racing or JC Whitney. About $140-$150 + installation.
No problem.
jschira is offline
Old 10-04-2003, 12:43 PM   #3 (permalink)
Re: Sway bar
I have a 4X4 and it was born on November 02. I will have to check to see if I have a front sway bar.
Boston is offline
Old 10-06-2003, 11:54 AM   #4 (permalink)
Re: Sway bar
they all have front sway bars, you are looking for a rear, If you're lookin!
I would say if you are happy with the cornering and sway when changing lanes and such, just leave it alone. NOW... if you looking for your next mod and have $150 burning a hole, then order youself one [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
2005 Midnight Blue Dodge Magnum RT...Yeah, it's got a Hemi!
TRADED 2000 "X" Limited, 4x4, Superlift 6", ProComp 35/12.5/16 Mud Terrains. Two Time Member: CPS F.O.R.D. club. water pump replaced at 51K.
4 SALE: 1996 Impala SS, Dark Green/Grey Metalic, 77K, Bridgestone Potenza RE730's, Dynamax's W/stainless tailpipes, 3:73's
Todd T is offline
Old 10-06-2003, 04:49 PM   #5 (permalink)
Re: Sway bar
Boston...
Had an '02 4x2 Ex without the rear sway bar and always felt 'uncomfortable' taking any corner without slowing to what I considered a crawl... and quick 'avoidance' lane changes were always and adventure... even had the mother-in-law HIT her head on the side windw when we hit a dip in the road !
I got the Hellwig... cussed about the horrible instructions, but LOVED the change in the handling of our 4x2 Ex...
The new '03 4x4 we have came with a stock rear sway and it SEEMS much smaller than the hellwig..
but seems to be acceptable thus far....
will probably swap it out after I finish my other 'personalization' efforts...
05 4x4 6.0L EB Ex.... only 2 mods..8.9 @ 74 1/8th
gone but not forgotten 03 4x4 6.0L Lim Ult Ex...
even goner 02 4x2 7.3L Lim Ex buyback
jdadamsjr is offline
Old 10-07-2003, 04:14 PM   #6 (permalink)
Re: Sway bar
John Boy
I will offer a quicker cheaper idea that I think will work.
Just replace the Excursion OE bar with a Ford 30mm SD bar.
I used part # F81Z-5A772-AA FOR 55.35 List I paid $43.17 The bar came with new rubber bushings on it so they all fit the same brackets.
That way you will be all Ford factory parts, see my pictures to make sure it will work I think it should, let me know how it looks compared to yours
I would think you could change out the bar only in less than 1/2 hour just 6 bolts and you are done!
For all the parts from dealer I paid $132.61 including tax total but no instructions and had to make the link arms shorter and cut down that big plate on the right shock attachment.
The 30mm is PLENTY of sway control.
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Just about finished!(never tell the wife you are done)
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 10-07-2003, 05:00 PM   #7 (permalink)
Re: Sway bar
Thanks and may be worth it...
Don't know the Helwigg size, but it was only $122 or so from JC Whitney...
will have to research the downlinks, etc
