As Chris stated I would do and in addition to that do another search in the 7.3L engine and drive train section. Do newer than 2 years and you will read more than you will ever want to know about the issues.
Jack
'02 PSD Excursion LTD Ultimate 4X4 Mineral Gray, PSD badges, Banks Exhaust, AIS air filter, DP-Tuner, Fuel mods, V code (2C3Z-5310-HA, AKA 3C34-5310-ADA) and modified F code (6C34-5560-F aka 5C32-5560-FA) springs with Timbren rear overloads, Bilstein shocks, hellwig sway bar, Powerslot Cyro rotors with Hawk LTS pads.
First, thanks for the help everyone gave me. I realy appreciate it!!
Just received my Hellwig anti-sway bars. They look strong but Hellwig has some of the worst quality control when it comes to painting their products. I ordered everything from Summit Racing, they were great!! I received the parts and noticed part of the sway bar was stuck to the box, as I pulled the bar from the box the paint pulled away. On the other side of the same bar the paint was crickled. I opened up the hardware box and all the painted parts were chiped or the paint fell completely off. The other sway bar was not much better. I had Summit resend me a new set, like I said they were great. Well, same thing, the paint job was crap. I called Hellwig and they said that they are aware of this. I was told that they do not let their products fully dry before packaging them for shipping.
OK
Have any of you had this same issue??
I guess my warning to those who want this product, be prepared to repaint your sway bars when you get them or have them powder coated. This sucks!! Hopefully they will mount easy and perform as advertised. I am confident they will with the strong edorsement you guys and gals gave me. In the mean time, the Hellwig anti-sway bars look like poo and the hardware looks worse.
Maybe Hellwig is monitoring this post and will get a clue.
Oh yeah. The paint quality on the rear bar I just got is for chit. Mine didn't stick to the box though. I intend to strip it and repaint it correctly. Maybe even some blingy color [img]/ubbthreads/images/graemlins/phoney.gif[/img]
Karl in NC
2001 Excursion Limited: exhaust, rear sway, Bilsteins
1995 Integra GS-R ITS/H3 race car for sale
SOLD: 99 Suburban, 98 trailer, 95 Integra, 90 CRX Si, 87 BMW, 73 MGB
I do not think so. I called Helliwig and told them about their poor instructions, cheap hardware and painting. This was over 2-1/2 years ago. I also told them about this site and the instructions on this site were far superior to their instructions. I asked them to monitor the site. How many sway bars has Hellwing sold because of this site? Still, I have not seen a post from anyone claiming to be with Hellwing or any quality improvements. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
John [img]/ubbthreads/images/graemlins/cool.gif[/img]
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
They are trying to match the factory paint on the axle. [img]/ubbthreads/images/graemlins/biggrin.gif[/img] If you look at my pics of my swaybar pay attention to that beautiful paint job on the axle. Paint just fell off.
Before the wrong big boxes arrive at my door, I want to make sure I am ordering the correct things. For an 03 4x4 X the front is a #7640 and the rear is a #7643. Correct?
2003 Excursion Limited-Aspen Green Metallic, 6.0, 4 X 4, quad captain's chairs, DVD, Silverstar Head lights/Fog lights, Fumoto drain valve, OEM mud flaps front and rear, Ultimat, TT-mirrors, Hellwig front and rear anti-sway bars, 2003 Powerstroke badges on rear door, sides and radiator, Harpooned fuel tank.
OK, since this now seems to be the active message on sway bars, let me post this over here too:
Have you guys actually measured the Hellwig front bar? Based on the other discussion that bounces around different sizes and calculations, I went and checked my rear Hellwig which is listed by them as 1.250". It measures 1.135". So I'm wondering if they list the size as a "relative" diameter based on chrome-moly stiffness rather then actual size, or maybe Hellwig changed the size between when I bought it and now.
Just an inquiry, not trying to make more out of this.
It should be the actual size. I'd call and see if they had a change, or maybe bad info. printed.
Those are the same part #'s I used when I ordered my Hellwig front and rear anti-sway bars from Summit Racing.
My 4x4 X is a 2002. Not sure if that matters. You can call Hellwig or go to their web site just to be sure.
I have not installed mine yet because I sent the bars and hardware to get powder coated last week. I should be receiving them back by the end of this week and installing them next week.
Good Luck!!
__________________ 2002 Excursion ~ Limited Ultimate ~ 7.3L PSD ~ 4x4
Mineral Gray, Limited Premier Group & Monochrome Package, two tone leather interior (pre-Eddie Bauer), TTT Mirrors, 3.73 Limited Slip, F250 Lariat wheels.
Kentucky Born: 4/9/2002 Improvements: 2002 PSD Badges, and lot's more!!
Sounds like "nominal overstating" like many aftermarket parts.
Thanks for the info though since the Ford bar is 30MM (I checked it) and this is 1.18 the Ford bar may be stiffer. Like I have said prior they are very close so if you have a factory bar why not just replace it with the 30mm bar for under $50.00 and save a lot of time also over replacing the whole system with the more expensive Hellwig that is apparently no stiffer.
BTW it does not matter what is in the steel the stiffness is the same the only difference is how much it will bend and still return to the original shape.
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available. Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket) 2005 Ex and Specs and Pictures of 2002 X
