Old 03-16-2003, 02:43 AM   #1 (permalink)
My Photos: (33)
swaybar?
Where's the best place to get a rear swaybar for my moms 2002 2x4 excursion?
any help would be appreciated.
1994 7.3 I.D.I. Navistar 444 CI
ATS Factory TURBO E4OD Red On white Crew Cab DRW 4:10 w/ AUBURN LIMITED SLIP
3" ATS Exhaust and turbo housing, Banks Trans Command, calibrated pump, K&N filter, Gruss style coolant filter, 203K+MI not a lick of trouble with the motor. now on 16th trans. 10 under factory 100K mile warranty
Alpine CVA-7878 XM radio 6cd changer 3 8" phoenix gold subs 75x4 Sony mobile ES gold 4ch amp, Sony 500W 1ch amp MB quart components in Q forms kick panels. 1 farad cap.
Pro car parts jewel cut headlamps and turn signals
APC clear cab markers, suvlights.com harness silverstar bulbs and L.E.D.'s in the fenders. IT's paid for and its MINE!
Family Toys and tools,
00'F350 psd CC Drw 2wd Bright Amber Western Hauler
SOLD 01' Peterbilt 330 4Dr. Texas trucks conversion cAt 350hp
02' Psd Excursion Limited ultimate Estate Green helliwig swaybar 101K miles
1996 fetherlite 4 horse GN, 2003 sooner 6 horse GN with midtack
Dualie is online now
Old 03-16-2003, 07:27 AM   #2 (permalink)
Re: swaybar?
www.summitracing.com
You want a part #? I'll go out to the barn and look at the box.
jschira is offline
Old 03-16-2003, 12:24 PM   #3 (permalink)
CHPMustang's Avatar
Re: swaybar?
We also picked up ours at Summit Racing for something like $140 shipped.
The part number on my invoice is HEL-7643.
BILL
2002 Ford Excursion 7.3L 4x4 XLT
9th Annual Powerstroke Rally this Oct 3-5 2008 in Caddo Mills,Texas
CLICK HERE for more Information & Register Here
CHPMustang is offline
Old 03-17-2003, 10:18 PM   #4 (permalink)
My Photos: (20)
Re: swaybar?
I received my Air Lifts from Summit with a $15 coupon for the next order so I ordered the Helwig rear swaybar. I put the Air Lifts on the rear today with Bilsteins and it looks great with 25psi.
Joe
jogiba is offline
Old 03-18-2003, 09:53 AM   #5 (permalink)
Re: swaybar?
jogiba:
How did the install of the Air-Lifts go? Where did you route the airlines to or do you have the compressor. I went to install my bags, but the kit had two passenger side brackets. Driver's side is on it's way. I'm a former bike owner as well, GSXR1100. Loved it. Drop me a line at ian.martin@cardinal.com
2002 4x4 7.3PSD Excursion, U-Codes, '03 Jounce Bumpers, Hellwig Sway Bar, Rancho 9000 shocks, Rancho Steering Stabilizer, Air-Lift rear air bags, Factory DVD, Driver side A-Pillar grab handle added, Rain-X wipersfront-24", rear-17"), riding on 285/75/R16 Bridgestone Revos.
IMartin is offline
Old 03-18-2003, 10:41 AM   #6 (permalink)
Re: swaybar?
jogiba:
Joe, I'm curious too! Any pictures? How long would you estimate? Any special tools?
Details details!! [img]/ubbthreads/images/graemlins/smile.gif[/img]
Regards,
Dave
2002 Excursion Limited - 7.3 PSD, 4x4, Auto. Tekonsha Prodigy Controller. ISSPRO EV Gauges in A-Pillar mount. Diesel Turbo Lifesaver. Pre-pump Mod. SCMT-Trimode. AIC. Back Door storage bins. Banks 3 1/2 inch Monster Exhaust. AIS. "U-Code" Springs. Powerstroker Exhaust Brake. Husky Liners. Bilstein Shocks. ART Brakes, Helwig Rear Anti-swaybar. Zoodad Mod. Airlift Rear Airbags. Racor 3550 CCV. Forest River Wildcat 26FBS TT.
2003 VW Jetta TDI - completely stock and 49mpg!
2003 Kubota B2910
dmftoy1 is offline
Old 03-18-2003, 10:02 PM   #7 (permalink)
My Photos: (20)
Re: swaybar?
Ok guys I just went out tonight and took five shots of the Air Lifts. They are in my gallery so just click on each one.
http://photos.thedieselstop.com/show...mp;ppuser=8110
The hardest part I guess was drilling for the lower brackets. I had my X jacked up in the driveway all weekend since I did not work on it full time (watching NASCAR etc)but I would say four hours for the Air Lifts . The right rear tire was a ***** to get off because of all the road salt this winter.
The most important tool is a good drill bit (3/8) for the lower brackets .
Joe
jogiba is offline
Old 03-19-2003, 10:16 AM   #8 (permalink)
Re: swaybar?
Really cool! THANKS!!
Just a couple of more questions.
1. Did you have to drill the frame to mount the upper brackets?
2. Do you have to remove the spring U-Bolts to install the lower brackets? (does it require you to support the axle, etc?)
Any chance of a scan/photo of the install instructions?
Of course NOW I'm going to have to order a set . . [img]/ubbthreads/images/graemlins/frown.gif[/img]
[img]/ubbthreads/images/graemlins/smile.gif[/img] [img]/ubbthreads/images/graemlins/smile.gif[/img]
Have a good one!
Dave
2003 Kubota B2910
dmftoy1 is offline
Old 03-19-2003, 10:57 AM   #9 (permalink)
Re: Swaybar/Air-Lifts
Joe;
Thanks for the pics. That is amazing! You mounted your air line stems exactly where I planned on mounting mine. Looks great there and is functional. Did the install require a lift? Did you install them yourself or at home? Do you have U or V codes? Why did you add the air bags. Sorry for all the questions. Thanks.
IMartin is offline
Old 03-19-2003, 10:59 AM   #10 (permalink)
My Photos: (20)
Re: swaybar?
Dave here is the link to the Excursion rear Air Lift instructions (PDF).
http://airlift.r-catalog.com/ImgVD/A...431(57340).pdf
The only drilling is to the lower strike plate (L&R sides)and for the air valves in the receiver. The upper bracket uses the hole were the old yellow stock jounce bumper was and an existing hole in the frame.
The U bolts are not touched unless you do the swaybar too. I used two jacks..one under the receiver and one under the axle with a pair of jackstands.
I have the front Air Lifts but I am not in a rush to put them on until we get some good weather again.
Have fun,
Joe
jogiba is offline
Old 03-19-2003, 11:59 AM   #11 (permalink)
My Photos: (20)
I did the install in my driveway with jacks under the receiver and rear axle. I have Air Lifts for the front instead of U or V codes so I can adjust the ride height with air pressure. I will install them when we get some good weather again. I am picking up my Citation 41ZBSR TT April 1st and will install a Hensley Arrow hitch with 1400lb spring bars on it . I need the receiver to be 18" (inside top 2" opening) when hooked up so the Air Lifts should make it easy to do after the spring bars are adjusted to shift weight to the front axle and TT axles. I also have a Sherline LoadMaster 0-2000lb tongue weight
scale on order to get a tongue weight after loading the TT.
Joe
jogiba is offline
Old 03-19-2003, 01:20 PM   #12 (permalink)
Great. Thanks. Good to see you're working the X like it was built to do.
IMartin is offline
Old 03-19-2003, 01:59 PM   #13 (permalink)
From what I can see in your pics, all of the downward pressure exerted by the air bags is on the "wing" of the rear block.
Are there any other contact points?
2001 Black Excursion, 4x4, XLT, PSD, LS, (EBM2), Super-Duty grill, 4" MBRP exhaust, Bilsteins, X-springs, OilGuard bypass filter, 295's, Badges, Suvlights harness, APC headlights, Weatherboots, Centramatics, Clear corners, AIC w/ITP mount, ISSPRO EVs, BTS trans, Open element intake, ATS compressor housing, Thule rack, BD Torqloc, F350 rear blocks, Randy Ellis lightbar with a couple of Lightforce 170s, Front receiver hitch, DP Tuner chip
1975 Ford Bronco, neglected since I bought the Excursion
AJ'sDad is offline
Old 03-19-2003, 03:15 PM   #14 (permalink)
My Photos: (20)
Just the way you see it here in the Air Lift install PDF.
It is just over 19.75" from the inside top 2" opening (with 25psi)on the receiver and I need 18" when hooked up to the TT. How are the Firestone Ride-Rites mounted ?
jogiba is offline
Old 03-19-2003, 03:24 PM   #15 (permalink)
The ride-rites are mounted basically the same, but instead of riding on the jounce bumper strike plate only, they have a bracket that attaches under the strike plate as well that spreads some of the load to the axle housing.
The ride-rite instructions are here: www.ride-rite.com/instruction_manuals/rrin2251.pdf
How much weight are your air-lifts rated for at max psi?
AJ'sDad is offline
» Network Links
