Old 04-30-2005, 10:09 PM   #1 (permalink)
Swaybar bushings
Which way should I go...OEM or Polyurethane?
'03, 4x4,6.0 PSD, Aspen Green X, Limited, 4x2 rear window strut mod., Bilstein Shocks, Walker BTM, Stainless exhaust tip, 30mm Ford rear swaybar
scubudo is offline
Old 05-02-2005, 10:15 PM   #2 (permalink)
clamgulch's Avatar
Re: Swaybar bushings
oem lasts longer but may not be repaceable depending on where you are talking about. Poly is tighter and cheaper but tends to squeek
clam the powerstroke grinch
2000 Excursion LTD 4x4
Slightly tweaked HPCR 5.9 Cummins
Allison 1000 5 speed auto
clamgulch is offline
Old 05-03-2005, 01:55 PM   #3 (permalink)
Location: Imperial, MO - 20 miles south of St. Louis, MO
Went oem with mine and have been perfect...no noise! Also, couldn't beat the price of $9.03 from Ford.
2000 X ltd.,white/parchment 4X4 loaded,285/75/16 BFG's,dvd,converted 06 oem grill,Xtint,New style clear headlights & clear corners w/ Plasma white bulbs,Fumoto,cut front bumps,Bilstein's,ass'd X badges & ass'd door PSD badges,ISSPRO EV gauges,clear cab lights, Wet Okole front seat covers, Weathertech visors,Pro-Comp steer stab.,Tymar Perf.intake, AIH removal mod w/boost tap,muffler delete turbo back Magnaflow 4" SS exhaust,WW,ATS Housing,Turbomaster controller,CCV Bypass,Edge Evolution Programmer(Extreme every day tow heavy in 80HP Mode),Power Slot rotors all around w/Hawk LTS pads,Duralast Gold Batteries, etc.); BTS tranny & new programming if oem ever dies.
In betweeen boats so now I have a custom 2003 HD Heritage Softtail I Love! Will return to boating when sons get older at 2mm LOTO, MO! Ride with friends now...Harley much cheaper on fuel!
http://community.webshots.com/user/jweiler27
Work hard, play hard; strive to be the best at whatever you are doing!
Jeff27 is offline
Old 10-17-2005, 02:04 PM   #4 (permalink)
Reviving an old post, but same question. Energy Suspension vs. Ford OEM. The Fords are $9 each, not sure about $ on E.S. but I'm guessing around $20 for both. Anyone try the E.S. bushings?
2002 X, 4x4, Limited Ultimate, 285 Dueler A/T Revos, Bilstein shocks, Edge mini-spring pack, F-350 4" rear blocks, Street Scene speed grill, Lund trim color bug deflector, Hellwig rear anti-sway bar, tinted front windows, Fram Sure-Drain
neilc88 is offline
Old 10-17-2005, 04:55 PM   #5 (permalink)
FamilyRide's Avatar
ES are polyurethane. Yes, they are more expensive. I think I paid about $30 for a kit for the fronts for an Expedition. It included new end links.
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 10-18-2005, 03:25 PM   #6 (permalink)
Pharmer's Avatar
Use the stock bushings, the PU will expand and you end up with a clunk.
03 Excursion Eddie Bauer 4WD 7.3L, 265 REVOS, U's and F's(mod), 3rd row headrests
68 Cougar xr7 390GT http://www.supermotors.net/vehicles/registry/3724
Pharmer is offline
Old 10-19-2005, 03:27 PM   #7 (permalink)
Thanks for the input. I'll stick with OEM.
neilc88 is offline
