switch in door latch ?? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 11-11-2009, 07:40 AM   #1 (permalink)
njneer1's Avatar
Is the switch for the interior lights built into the door latch ? My LH rear door has quit turning on the lights
2000 Limited, 118K, 7.3L, 285 Cooper ATR's, super chips 1705 on tow/performance, Bilsteins, Isspro EGT/Boost/ Trans temp.
1997 4runner,5spd,TRD supercharged,Bilsteins,H&R coil springs front and rear
1968 roadrunner,383,4spd
1970 roadrunner,383,4spd,pistol grip,58k 0riginal miles
1970 Charger,383,4spd,pistol grip,my first car
njneer1 is offline
Old 11-11-2009, 09:05 AM   #2 (permalink)
LOOSEWHEEL's Avatar
Yes it is. Try spraying a little WD-40 into the latch. It's a common issue that they become gummed up.
2001 F350 CC SWB 6spd WHITE 8.5" on 37's. Currently getting a complete makeover......stay tuned.
Pics
'Everything is possible if you don't know what you are talking about'
LOOSEWHEEL is offline
Old 11-11-2009, 08:19 PM   #3 (permalink)
njneer1's Avatar
Thanks again Loosewheel, I'll give it a shot. If it doesn't work, can just the switch be replaced ?
njneer1 is offline
Old 11-11-2009, 11:33 PM   #4 (permalink)
LOOSEWHEEL's Avatar
The switch can be replaced but I am not sure you can buy it separately. The latches are common on a lot of FORD vehicles, so you might be able to go to a wrecking yard and pull one. Let me know how you make out.
Pics
Old 11-12-2009, 05:50 PM   #5 (permalink)
njneer1's Avatar
Hit it with the WD40, no luck freeing it up yet
njneer1 is offline
