Hi all, I tried a search both here and in towing but come up empty as my search-fu is very weak today.
I want to tow a relatively light trailer with my X and am looking at the Tekonsha P3 as the controller.
I know there is a wiring connector up under the dash somewhere near the radio (?) for a plug in controller, but does Tekonsha sell an in-between piece that allows their P3 brain (4 wire connector) to connect to Ford's harness?
Anyone got any advice?
2005 Eddie Bauer X -- all stock.
So when their brochure mentions that the pigtail 3065P fits 2005-2007 Superduties, am I am expect that a SuperDuty pigtail will fit my (mostly Superduty but some parts and wiring bits are uniquely) Excursion?
I would think that Ford has some things that are "standard" across some model lines for the same yr. For instance they probably use the same starter, alt, and some other common parts. Based on that I would probably get the pigtail. Brake controler wiring for tekonsha is pretty much "universal" The pigtail just makes it "plug and play".
1994 F-350 7.3 IDI Turbo, crew cab, E4OD, LB, Dually,
1997 Jayco fifth wheel 323 RKS, Robins 16K dual axis hitch
Apillar pod with: Autometer C2 Series gauges: pyro,trans, boost
Hypermax Cowl induction, Flex-A-Lite 26K tranny cooler w/fan
K&N air filter (we'll see in a million miles)
Tekonsha "prodigy" brake control
Train Horns: Pictures here
Delivery was about two days and Free also, best deal I could find.
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available. Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket) 2005 Ex and Specs and Pictures of 2002 X
Yeah, I thought my P3 wasn't working because it was so smooth, not jerky like the old one. Stab the brakes and it'll lock the trailer tires though.
FS
'01 X 7.3 to tow my racecar...
AIS w/ sleeve
S.S. HX(removed for now)
4" MBRP
FPR shim
TransGo shift kit
Hellwig rear bar
Landyot's Radius Rods
DP Tuner-80E, Hi Idle, 60 tow
EGT, Trans temp, boost gauges
'99 E350 Snake Oil Wagon, 200+K, doesn't burn oil, lives on the bump stops & has a hard life. Runs like new.
'91 Spec Miata
All vehicles full of BG Synthetic Fluids
Charlene at Tekonsha says p/n #3035 fits the 2005 X.
Southwest Brake and Wheel won't free-ship to Canada, won't USPS to Canada and will ONLY ship via Fed Ex 6-10 day service for $38 or 1-2 for $65. Unbelievable.
Reason: to correct the gouging that Soutwest is charging for shipping. Slap a sticker on the box.
Bought the P3 locally and the harness. AWESOME controller. Easy to set up and works very well. Nice that you can change the display colours to suit your truck. I set mine to green to match the Ford dash.
Couldn't be happier with the P3.
I also love my P3; worth every penny! Adjusting from an empty trailer to a fully-loaded trailer is as simple as pressing the boost-button until the icon matching your load appears.
As for the harness connector, on my '00 it was fastened to the stamped-metal dash support up to the right from the under-dash access panel, which made it real difficult to plug in the controller harness.
I just pried the connector off the support, which made it much easier to plug in.
