Was by a shop today and they had upgraded (lifted) their F250 FX sport crew cab 4X4 purchased in August 2003. The springs from the fronts say 2C34 ADB R 310 2. Are these the correct springs for a suspension upgrade on a 2003 X 4X4 with 6.0? If I use these will I have to change the rear also? What improvements can I expect?
Jim
PowerTug
03 Excursion Limited PSD 4X4 3.73 LS
Build 3/20/03, C95 Injectors, Updated VGT, December 04 flash, Harpooned, Second Hot Water Shutoff Added for A/C, Updated DVD Entertainment Center wireless headphones, SiverStars, Fog Light Retro with 9005 SilverStars
Average MPG 17.5?, City MPG 16?, Highway MPG 19.5?, Towing Bass Boat MPG 17?
I'd recommend to check the truck's door tag the springs came off of to verify if they're U's,V's or W's.
The V's should be fine with the 6.0's,the rear springs will rest in after awhile to which you could go with the F350 rear blocks or air bags to pick up the height you lost.
I went with the blocks for SDHQ had a pile of them and purchased a new set of U bolts w/nuts to go with the blocks.
The advantages to correct springs (U,V,W or X)is a way way better ride and handling,I noticed that just as I got on the freeway for a test run it's a whole different truck [img]/ubbthreads/images/graemlins/cool.gif[/img] [img]/ubbthreads/images/graemlins/cool.gif[/img]
BILL
__________________ 2002 Ford Excursion 7.3L 4x4 XLT
BTS Transmission,6.0L trans cooler,13" PI Stallion TC
Magnaflow 4" exhaust and a multitude of other mods
I went back and looked at the door sticker - it says SPR VP if that means something. Are the 'VP' the same as 'V'? Also will the 'VP' be stiffer or softer than the ones on my 2003 X? Any Idea on what a fair price to install them would be?
Thanks agian
Jim
PowerTug
Can't help on the spring codes but I paid $120 to install my "V" codes, '03 bumps and Ranchos. Of course he quoted the price before he figured out he would have to pull the front bumper. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
You gottit Jim,they're "V" codes with a rear spring code of "P",so when you see another truck or Excursion's SPR code you'll know what the codes are for front and rear [img]/ubbthreads/images/graemlins/cool.gif[/img]
Lemme locate the PDF with the spring capacities/codes breakdown and I'll post it up.
My spring PDF is abit out of date,I believe it covers to 2002,so the "P" code must be one of Ford's new ones,but I'm searching for an updated version.
BILL
So my X comes with 'DG' springs and I'm looking to change to 'VG'. does this sound right? I wonder if it will still sit level when done [img]/ubbthreads/images/graemlins/crazy.gif[/img]
Jim
PowerTug
You'll just need V codes. The G just represents the rear spring code. Ford puts em together to save space on the tag [img]/ubbthreads/images/graemlins/grin.gif[/img]
Measuring at the tops of the fender wells, my truck had about 1.75" to 2" 'rake', meaning the rear was higher, with the stock "D" code springs. After installing the "V" codes it measured the same height front and back. However, it "looked" nose high. It seems that all of the accents on the truck are designed to look correct when it has the factory rake. If you measure the pinstripe and crease at the top of the doors and quarter panel you will find that they fall away if the fenders are level. I'm not sure what they do when it's sitting at the factory angle. Never checked. It looked right. I found that installing the F-350 rear blocks returned the truck to what I felt was the proper angle.
The only problem now is that the 265 tires that I spent $864 on 6K miles ago look too small. [img]/ubbthreads/images/graemlins/blush.gif[/img]
I swear it never ends. [img]/ubbthreads/images/graemlins/crazy.gif[/img]
The only reasons I got the 285's was I was adding the bumper and getting a set of F350 blocks installed at SDHQ,and the Excursion now has the rake it had when the X was brand new.
BILL
