Tight Shift Lever - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 11-28-2012, 11:12 AM   #1 (permalink)
dieseldo's Avatar
Tight Shift Lever
Greetings, anyone had any problems with a hard to move shifter?
2000 Excursion Limited, Black, MBRP 4" stainless turbo-back, 229,000 miles, home-made Tymar intake, DP-5,
Pyro,Tran.Temp & Boost gauges
1990 Miata, Red 199,000 miles
2005 Rubicon, Orange, 76,000 miles
dieseldo is offline   Reply With Quote
Old 11-28-2012, 12:24 PM   #2 (permalink)
Yes take the access panel off under your steering column. Then lay down on the floor looking up at the column underneath. There are 2 bolts that hold the shifter in place if they are loose or missing you can bend your shifter tube. I had mine drop a screw and the other go loose. This happened to my 2000 F250 7.3. She had about 81,000 miles on her and was 81/2 years old at the time. Other than that maybe someone else can come up with other options to look for. Good Luck
aleutianman is offline   Reply With Quote
Old 11-28-2012, 02:49 PM   #3 (permalink)
dieseldo's Avatar
Thanks, I will look at that.......
Old 12-08-2012, 12:17 PM   #4 (permalink)
MotionMan's Avatar
I am not sure if the X is different from the PU but I just pulled my bottom cover and I could not see any bolts. I did have to replace the shift arm due to a bad OD button and I remember them being on the top. I did not verify this because I did not want to pull the ignition out....but I did when I replaced the arm. There are 2 black plastic bushings that the arm rides on when moved, I bought them for when I did the arm but it was more involved and I skipped it. I still have them in case. My arm seems loose but the dealer said the bushings were the fix, I guess when I hear metal on metal I will have to dig in.
2003 7.3 Excursion Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, Top Gun Bumper, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. PIAA Lights, Toyo 325/60/18s on Chrome Alum rims.
MotionMan is offline   Reply With Quote
Old 12-08-2012, 01:17 PM   #5 (permalink)
Mark Kovalsky's Avatar
The X is identical to the pickup. The bolts are not under the cover, you don't remove the cover to find and tighten the two Torx head bolts. They are near the floor.
Another likely place is the TRS on the driver's side of the trans. It is the part where the shift cable attaches with the wiring harness. I've seen them get hard to move.
Mark
Mark Kovalsky is offline   Reply With Quote
Old 12-12-2012, 09:02 PM   #6 (permalink)
MotionMan's Avatar
Ah ha, an expert. My problem is what seems to be a loose shift arm, it has a good bit of play in it. It moves fine and all but it just seems to have play in it. Would this be the bushings? If you read the post it read like the bolts were under the cover. Where on the floor might I find these. Thanks.
Old 12-13-2012, 08:07 AM   #7 (permalink)
They are not under the cover, and they are not on the floor. They are on the steering column just above the floor. There are two bolts with Torx heads. Before replacing bushings make sure these bolts are tight.
Mark
Old 12-13-2012, 05:19 PM   #8 (permalink)
MotionMan's Avatar
Thanks, I will check them out. I'm saving your name, I bet you know these like the back of your hand. I have the bushings, I ordered a new steering wheel since mine is all worn and looks horrible. I think I will look at the bushings when the wheel comes off but this I can do now. Happy Holidays.
Old 03-05-2013, 02:34 PM   #9 (permalink)
garryk6's Avatar
Can this be checked by just disconnecting the cable from the trans, and then seeing if the tightness is in the column/cable or the trans?
Thanks, as my 00 is really stiff to shift...
Garry
2000 EX XLT 4x4 Supercharged V-10, 4.30 gears, Stock for now...(In Kodiak, AK)
2001 Nomad 308 (32" w/ 14' Slide) Bunkhouse (in WA State)
2000 Excursion V-10 4x4 120k Bone Stock and still running strong! (In WA State)
2002 F350 XLT 4x4 CCSB SRW 5.4 V-8 6-Spd 17,811 original miles (Bought 2-5-10) 19.5 Visions 265-70-19.5 Load Range G Michelan AT's; Mile Marker SS Hubs, Helwig Sway Bar, Rancho RS9000's (In Kodiak, AK)
1966 Avion C-10 Truck Camper (In Kodiak, AK)
4 kids and love to travel and camp!
garryk6 is offline   Reply With Quote
Old 03-05-2013, 06:01 PM   #10 (permalink)
Yes, that's a good test to see if it is the TRS or not.
Mark
