tow rating - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 04-28-2009, 06:18 PM   #1 (permalink)
tow rating
what did ford change on the excursions from 2000 to raise the tow rating from 10,000lbs to 11,000lbs??
Dirtcheap is offline
Old 04-29-2009, 01:46 PM   #2 (permalink)
As I recall the numbers printed on the hitch and in the manual; however if you have a 2000 then it is rated at 10K not 11K
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Just about finished!(never tell the wife you are done)
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 04-30-2009, 10:49 PM   #3 (permalink)
78Southwind's Avatar
Though I have been told that the frame is thicker on the 2001.5 and later the only thing that I have found is that the 2000 hitch uses 14mm bolts while the 2001.5 and later hitch uses 18mm bolts.
2000 Excursion Limited (BUILD DATE
05/31/2000) 4X4, 7.3 PSD, 3.5" LIFT and SuperChip
78Southwind is offline
Old 05-01-2009, 03:24 PM   #4 (permalink)
mine is 10,000lbs i was wondering what is different on the later models to make the ratings heavier
Old 05-01-2009, 04:15 PM   #5 (permalink)
aklim's Avatar
So size matters?
Seriously, If I were to change those bolts, would it realistically make the thing better?
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U code front and A code Rear.
aklim is offline
Old 05-08-2009, 09:46 PM   #6 (permalink)
The rating is limited because of the receiver-hitch rating. If you look at the previous pictures the first receiver-hitch has a rating of 10,000 lbs. and the second hitch has a rating of 12,500 lbs. the only thing I could find different were the bolts. The 2000 up to 2001 is limited by the hitch the 2001.5 to 2005 is limited by the GCWR. A loaded excursion is about 9,000 lbs. minus that from the 20,000 lbs. GCWR that leaves 11,000 lbs.
Old 05-08-2009, 10:00 PM   #7 (permalink)
Originally Posted by aklim View Post
So size matters?
That's what I did. I wasn't worried about towing over 10,000 lbs. I wanted to be able to carry more tongue weight if need be. However, the 2000 receiver-hitch bolt holes are smaller so they would have to be drilled out or you would have to find a 2002 receiver-hitch like i did. I pretty much scored I found the receiver-hitch and bolts for $50. The bolts alone from most companies are over $100. It's difficult job drilling the bolts out though.
Old 05-09-2009, 11:05 PM   #8 (permalink)
so all i need is to find a factory hitch (and bolts) for a 2002 X and im good?
Old 05-11-2009, 08:21 PM   #9 (permalink)
MotionMan's Avatar
what did you use to get the rivets out? mine is a rusty mess and the hole is pounded out from rush that is flaking off...which was once metal. They say the hitch is over $500 and labor was $300...thats just wrong. I was thinking of sand blasting it but it should be replaced.
2003 7.3 Excursion Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, Top Gun Bumper, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. PIAA Lights, Toyo 325/60/18s on Chrome Alum rims.http://community.webshots.com/user/stellinm
MotionMan is offline
Old 05-13-2009, 01:38 AM   #10 (permalink)
Yep. I wouldn't use the torque bolts though in case you want to take the receiver hitch off. I would just use 8 bolts of part number W708082-S426. The following is an e-mail I got from Ben at Powerstrokeshop.com - PSD and Ford Superduty Parts when I was doing my research.
Jerry, I believe that you are right about the bolts. The following part #'s will help upgrade your hitch. W708082-S426 (qty. 6) W707796-S427 (qty. 4) and 1C7Z17758AA (qty. 2). I am going to order some of these in for stock so I can compare the difference. I will let you know what I find. Thanks -Ben-
Old 05-13-2009, 01:54 AM   #11 (permalink)
The two torque bolts need to be drilled out. For me this was a very time consuming process. I only dropped the tank about 2" or so and used magnet to retrive and place the bolts. Here's a couple pictures of the process.
Bumper pulled off
Retrieving drilled out bolt and nut.
Dropping the hitch
Comparing the two
Old 05-13-2009, 01:56 AM   #12 (permalink)
Dropping the tank
New Bolts I didn't use the torque bolts so I could take it off if I wanted to
Bolts inside frame
2002 Hitch
I hope this helps you. I will see if my workshop manual has any detialed instructions on the drilling process.
Old 05-13-2009, 02:23 AM   #13 (permalink)
Trailer Hitch — Excursion
Removal and Installation
WARNING:
Do not permanently remove the trailer hitch. Always reinstall the hitch before delivery of the vehicle to the customer. The trailer hitch is designed to enhance fuel system protection, helping reduce the potential for fuel leaks in the event of a rear end collision. Failure to follow this warning could increase the risk of injury in a rear end collision.
Note:
Do not reuse body support mounting fasteners. New fasteners must be installed for each fastener that has been removed or loosened.
1. Raise and support the vehicle.
µ2. Loosen the four fuel tank shield bolts. Do not remove the bolts.
µ3. CAUTION:
New shear bolts with the same part number must be installed. Do not use fasteners of lesser quality or substitute design. Torque values must be used as specified during installation to ensure correct retention of the trailer hitch.
Note:
The fuel tank shield will have to be positioned to one side and then to the opposite side to gain access to the trailer hitch mounting fasteners.
With the help of an assistant, remove the trailer hitch.
1 Note the location of the shear bolts prior to removal. Remove the two shear bolts in three stages.
n Stage 1: Using a 1/8 in. drill bit, start a pilot hole.
n Stage 2: Using a 1/2 in. drill bit, drill out the center of the shear bolt.
n Stage 3: Using a suitable air chisel, remove the head from the shear bolt.
n During installation, tighten the shear bolts until the bolt heads shear off.
2 Remove and discard the six bolts.
n During installation, install new bolts.
3 Remove the trailer hitch.
4. Remove the four nut and retainer assemblies. Remove the remainder of the two shear bolts from the nut and retainer assemblies.
l If the nut and retainer assembly is damaged during shear bolt removal, install a new nut and retainer.
5. To install, reverse the removal procedure.
Old 05-14-2009, 09:06 PM   #14 (permalink)
texaspsdx's Avatar
What is the part # for the hitch? Is there an inexpensive place to buy it?
Ron
2000 Excursion Limited 2x4, 4.10 w/Detroit TrueTrac, PSD/Auto, ATS turbo shroud,Badging, 4" exhaust w/AeroTurbine 4040XLL, AIS, HX crossover, ISSPRO gauges/A-Pillar, SuperChip 1705, Pre-Pump & In-Tank Mod, Banks TransCommand, ZooDad, Baldwin Oil ByPass, Ford AIC, F350 rear springs, Helwig Rear Sway Bar, Michelin's LTX MS,
1983 Avion 34V - 35' travel trailer,
Hensley Arrow No Sway Hitch
texaspsdx is offline
Old 05-20-2009, 02:55 PM   #15 (permalink)
I don't think I have the part number but I know you can buy it thru Your Premiere Source for Ford Truck Parts and Accessories for about $350. Just make sure you buy a 2002+.
