Track bar needs new bushings - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 02-11-2006, 10:54 PM   #1 (permalink)
Mudraga's Avatar
I've been hearing a clunking sound coming from under my feet when driving. So I was underneath today shaking things until I found the track bar moved a little. The upper bushing appears to be worn out. I suspect thats the sound I'm hearing (and feeling). Is this a common maintenance item with only 67k miles on the truck? Anyone have recommendations for a place to buy new bushings for the track bar?
2002[1/02] Excursion 4x4 Ltd. PSD,Unknown program, K&N GenII FIPK Air Filter, straight pipe exhaust, Autometer Z Series pyrometer and boost gauges, Air Lift SuperDuty air bags with Load Controller II onboard air system, Sonnax Tricumulator, HX hose.
Mudraga is offline
Old 02-12-2006, 03:13 PM   #2 (permalink)
clamgulch's Avatar
Re: Track bar needs new bushings
Track bar bushings are molded in place, and it is not unusual for them to be shot at 40,000 miles. I replaced my track bar with an adjustable one from Skyjacker and I'm happy with it.
The clunk under foot is PROBABLY the end link on the front sway bar. There was a TSB on them at one time. They appear tight but under a load they flop around because the hole dameter is much larger than the bolt. Tighten the snot out of them- I think they upped the torque to something like 140 foot pounds, but don't take my word for it. You twist off the bolt and a new end link is about $80.
clam the powerstroke grinch
2000 Excursion LTD 4x4
Slightly tweaked HPCR 5.9 Cummins
Allison 1000 5 speed auto
clamgulch is offline
Old 02-12-2006, 05:05 PM   #3 (permalink)
Soaggydogg's Avatar
My Photos: (11)
Feedback Score: 2 reviews
What is the advantage of an adjustable one? And what did you give for that track bar?
'95 F250 Ported Snorkle, Foil Delete and a little more
'02 Excursion Matched Perfect and Staggered Special
Total Diesel Performance Custom Tuning
Rockin S Performance BTS dealer
good-times.webshots.com/photo/2120855500037306169oDlfMF Well did you touch it?
Soaggydogg is offline
Old 02-12-2006, 11:30 PM   #4 (permalink)
I too had a clunking noise coming from the front drivers side. My clunking was coming from the front sway bar bushings (the bushings that mount to the axle). The Ford part number for the bushings I bought is YC3Z-5484-BA and were only $9.90 a piece from the dealer. These are very easy to replace, about 15 minutes. Have someone rock the vehicle back and forth while you are underneath, listen and watch where the noise is coming from. I could easily see and hear where the knocking was coming from, if I grabbed the sway bar the noise stopped.
If those bushings aren't causing your clunking check the link bushings on the sway bar or your ball joints.
Dan
2003 Excursion - 6.0
bookem is offline
Old 02-20-2006, 05:45 PM   #5 (permalink)
I've had mine replace four times in 55,000 miles. They seem to go out when you do a steep angled approach...
2002 4x4 7.3PSD Excursion, U-Codes, '03 Jounce Bumpers, Hellwig Sway Bar, Rancho 9000 shocks, Rancho Steering Stabilizer, Air-Lift rear air bags, Factory DVD, Driver side A-Pillar grab handle added, Rain-X wipersfront-24", rear-17"), riding on 285/75/R16 Bridgestone Revos.
IMartin is offline
Old 02-20-2006, 10:12 PM   #6 (permalink)
clamgulch's Avatar
sorry, I didn't check this thread in a while. Adjustable one is a tube with heim joints at each end. They don't have a rubber component to wear out, so the steering is tighter. Additionally, they are adjustable for recentering your steering wheel.
Can't recall what I paid for it but it was made by Skyjacker.
