Trailer Wiring Question on my 03 Excursion - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 12-17-2009, 03:12 PM   #1 (permalink)
Background if kept my tired old Suburban, towed the car trailer with it last night and noticed that the trailer's interior lights work with it.
They have never worked with the Excursion, asked my friend with an F250 truck and he said his have never worked either.
So, is there a way to wire the hookup so the lights do work?
Thanks for any help
RustyNCA
RustyNCA is offline
Old 12-17-2009, 03:26 PM   #2 (permalink)
njneer1's Avatar
sounds like you need to swap you trailer lights to the center "auxillary"pin on the 7 way, See if this helps
Trailer Wiring Diagrams
2000 Limited, 118K, 7.3L, 285 Cooper ATR's, super chips 1705 on tow/performance, Bilsteins, Isspro EGT/Boost/ Trans temp.
1997 4runner,5spd,TRD supercharged,Bilsteins,H&R coil springs front and rear
1968 roadrunner,383,4spd
1970 roadrunner,383,4spd,pistol grip,58k 0riginal miles
1970 Charger,383,4spd,pistol grip,my first car
njneer1 is offline
Old 12-17-2009, 04:53 PM   #3 (permalink)
carringb's Avatar
No, that will only make them work when he's in reverse.
There is an open spot in the power distribution box under the hood. Stick a new relay there, trailer battery circuit will now work any time the key is on.
2000 E350 DRW XLT extended wagon (yes! it's a dually!)
17" Ultra Goliath rims
Banks Powerpack, Diablo Predator
Buckstop front bumper, Reunel rear w/ 20,000# reciever
250,000+
carringb is offline
Old 12-17-2009, 05:35 PM   #4 (permalink)
It's that simple as putitng a relay in the distribution block? No wires to run, and it will only work with the key is on? I see the wisdom in that, but is there anyway to make it hot all the time?
RustyNCA
RustyNCA is offline
Old 12-18-2009, 08:16 PM   #5 (permalink)
RustyNCA
Randy here is the pinout fom my 2005 dvd
You should not have to add a relay it should be in your truck.
The pin you want is pin 5 the orange trailer battery charge circuit.
As said below it is only hot in run.
You could add a small batery to your trailer or add a breakaway battery and circuit.
Then the lights connect to the battery and the you use the circuit 5 as intended to charge a battery. Some states require a breakaway circuit as I understand it. Not sure if there are restrictions on using this battery for lighting. Should work fine since you use the lights while parked.
Pin----Circuit
1------52 (YE) Trailer tow relay, left turn, switched power
2------206 (WH) Ground
3------43 (DB) "not used" But wired for your brake controller
4------64 (DG) Trailer tow relay, right turn, switched power
5------49 (OG) Trailer tow relay, battery charge, switched power
6-----962 (BN/WH)Trailer tow relay, parking lamp, switched power
7-----963 (BK/LG) Trailer tow relay, reversing lamp, switched power
Hope this helps
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Just about finished!(never tell the wife you are done)
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 12-21-2009, 02:24 PM   #6 (permalink)
I didn't have to add a relay to get my trailer lights (horse trailer interior light in parallel with the battery charger circuit) to work. I did have to add a fuse in the junction box under the hood. I would tell you which one but the wife has the Excursion today. Look in the owners manual on the power distribution fuse page - it is listed as something like the trailer battery circuit. Separate from the trailer brake circuit. From the factory there was no fuse there, but all the circuit is in place.
Proud American
01 4WD PSD Ex - EBM2 - Autometer's on the A, Mag-Hytec Tran Pan, Front Hitch, Dome Light Override, TTM, Tymar Intake, Coolant Filter, Hellwig Bar, Walker BTM, BTS Trans, DP-Tuner, BIG SMILE!
scott-c is offline
Old 12-26-2009, 06:40 PM   #7 (permalink)
That's position 115 in my manual. Did you add the suggested 30 amp fuse or go with something lighter because you were using it only for trailer interior lights, not trailer battery charge?
Thanks,
DOC
DOC4444 is offline
Old 12-27-2009, 04:11 PM   #8 (permalink)
Position 115 on my rig already has a 30 amp fuse in it. Would the member who mentioned adding a relay to the fuse box care to mention what position that was?
Thanks,
DOC
DOC4444 is offline
