Truck lights and dash going CRAZY HELP!!! - Diesel Forum - TheDieselStop.com
post #1 of 14 (permalink) Old 12-25-2007, 09:46 PM Thread Starter
Need help. i've got a 2003 Excursion 7.3. The truck all of a sudden started acting weird. The dash is flashing. All the gauges are going to max and zero max and zero, the lights are flashing, there is a constant clicking noise in the dash, its going crazy.
I need help, have to drive home from Christmas and I don't know how to stop this.....
Thoughts?
DieselDunn is offline
post #2 of 14 (permalink) Old 12-25-2007, 10:32 PM
JLMMA's Avatar
Re: Truck lights and dash going CRAZY HELP!!!
Im no expert but I think I read a thread about this the other day and it was the voltage regulator for the alternator. you should look through the recent threads and see it you can find it. It might be smart to have the alternator tested I know its christmas so that might be a problem. Hope everything works out.
Merry Christmas
2000 F-350 PSD 4x4 SRW RegCab "Sophie" Mods: FS 2500 bypass filter, BFG AT 305 65 R17s on American Racing Rims, 8' Fisher Plow, Whalen corner strobes, Line-X, Tinted Windows, Scangauge II, Optima Red Top, Warn Hubs. DIESEL POWER!!!
JLMMA is offline
post #3 of 14 (permalink) Old 12-25-2007, 11:07 PM
Will the truck start? Does it have good batteries, as clicking in the dash is usually indicitive of low voltage? I am not familiar with the Excursions, but I believe they had PATS in the 03. In that case I would try another key and/or start looking for the relay that is clicking in the dash. Good luck and hopefully someone with more experiance with this system will come along. Just my thoughts.
2004 F-350 Lariat, Supercab 4X4 FX4, DRW
Dark Toreador Red/Silver, 6.0L, Torqueshift Auto, ESOF, 4.10 LS, Camper Package, Dual Alternators. Build Date 6-8-04, Eng 5-28-04, Lance 9.5 Ft Camper.
Past 2002 F-350 Lariat, Supercab 4X4, Toreador
Red, 7.3L, Auto, DRW, Fully Loaded.
Past 94.5 F-250 Lariat, Supercab 4X4, 5 spd 7.3L PSD.
DRJ48 is offline
post #4 of 14 (permalink) Old 12-26-2007, 01:40 AM
Kanman's Avatar
Your batteries are discharged. Put them on a charger for at least a few hours. Better have your alternator checked out too.
Kanman is offline
post #5 of 14 (permalink) Old 12-27-2007, 09:13 AM Thread Starter
bats are good charged and new. Still not fixed. Can't get home till it happens.
post #6 of 14 (permalink) Old 12-27-2007, 11:44 AM
Kanman's Avatar
Check/clean the connections on your brand new batteries and then charge them.
Kanman is offline
post #7 of 14 (permalink) Old 12-27-2007, 06:49 PM Thread Starter
alternator isn't charging. Or just barely charging so we are going to change that out tomorrow. Hoping this will fix it.
post #8 of 14 (permalink) Old 12-27-2007, 10:04 PM Thread Starter
alternator didn't fix the problem.....
post #9 of 14 (permalink) Old 01-03-2008, 08:35 PM
Check your grounds. Battery to frame, engine to frame, body, everything.
You could also go to your friendly neighborhood autoparts store to see what codes are being tossed.
New addition:
2006 f-550 service body with a 20 foot stellar crane.
Arrest me red 2006 F-250 6.0 Even more loaded
Black 2000 F-250 4X4 PSD Lariat, loaded.
Green 2001 4x4 Excursion Limited with PSD, loaded
White 2004 F-250XL, it is loaded with just a LS. I can't find the other options.:P
Just how many superduty's does a guy need?
The-washer is offline
post #10 of 14 (permalink) Old 01-05-2008, 05:34 AM
are your door locks going wacky also?
'02 PSD LTD Ultimate X Rancho17000's/Ucodes/SkyjackerDual steering stabilizer/Addco Swaybar/REVO'S/Stuhl billet grille/17"Ford Air Horns Behind the grille!
ford_x_3 is offline
post #11 of 14 (permalink) Old 01-05-2008, 07:58 AM
clamgulch's Avatar
It definitely sounds like grounds. I disconnected a ground inside the Excursion one time when I had the engine out and was doing some interior work and forgot about it for months. When I put the engine back in, the horn would honk when I rolled down the windows, some windows wouldn't work at all. So I jumped to conclusions and assumed that the GEM (generic electronic module) had gotten wet and corroded and I replaced it. What a PITA. Especially since it didn't solve the problem. Then one day I reinstalled the interior and there was the ground wire laying loose. Whoopsie. Put the bolt in it and that solved the problem.
There have been past reports of superduties and excursions getting water dripping down into the GEM from a leaky windshield. It's attached to the top side of the fuse box under the dash, driver's side. Hopefully, that's not your problem.
I'd try loosening and retightening every ground I could find.
clam the powerstroke grinch
2000 Excursion LTD 4x4
Slightly tweaked HPCR 5.9 Cummins
Allison 1000 5 speed auto
clamgulch is offline
post #12 of 14 (permalink) Old 01-07-2008, 01:33 PM
Not sure if your still having this problem. About 6 months ago I had the same thing happen. Never really found out what was causing the problem. I check all ground and battery connections still had the problem. As a last resort I changed out the PCM problem went away not sure why but it worked for me
Stock 2000 Excursion limited 4X4 7.3
wbutton is offline
post #13 of 14 (permalink) Old 01-08-2008, 07:11 AM
check the ground wire that is inside the left rear trim panel, it can be reached by removing the flip up arm rest with the lighter in it. then yolu reach up and towards the rear and its bolted to the body
2002 Excursion LTD(PCM:NQW5)Pheltech Tru-Cowl Induction Hood BTS transmission FASS and ITP fuel system, 38/15.5/20 Toyo's on Weld 12" wide wheels,15k warn and warn 9.5k rear 4:30s ARB air lockers front and Dana80 rear. Trail ready front bumper,Road Armor rear bumper light force driving lights, PIAA backup lights,Dakota digital gages, F5 DP tuner chip,Hypermax stage 2 injectors,4" exhaust, 11" Edge lift, King shocks, edge crossover steering, ORU ram assist steering
OneUp ladder bars,TN turbo, Dynatrac conversion kit. Alpine F1, Zapco amps. two dc1100.1, three dc1000.4, 1 dc750.2, driving seas reference series front stage and Zapco competition rear fill and 2 Jl audio 13w7 subs
AP Racing big brakes, Amp Research running boards
coldair is offline
post #14 of 14 (permalink) Old 08-30-2009, 12:39 PM
Dunbar's Avatar
Wow, lots of grounds to check! Will keep searching then go look at grounds.
Dunbar
David Dunbar
2003 4x4 7.3 Excursion Ltd
4" exhaust, Tymar DIY, Vcode & modified Fcode, Helwig, Inappropriately valved Bilsteins, Isspro 3 gauge w/ windshield mount, DP tuner 80-60tow-40tow-HI, 6.0 31-row ATF cooler,
BTS Transmission, DI Up pipes
Tomball Texas
Dunbar is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
