u bolt part numbers? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 05-04-2007, 09:06 AM   #1 (permalink)
BDS
I am getting an order together to do a spring swap on a guys Excursion with a v10. I am going to do the u-codes for the front and the modified F codes for the rear. What u-bolts did you guys use? Where they the regular ones for a F250-350...I', also currious if they are long enough after adding the Excursion overload spring as a shim?
I tried to find them on Powerstroke.Com and gave up!
Brent.
96' F350 XLT C/C PSD 4X4 LWB-Green...His, SOLD IT, Stupid Move, Found Another!
97' F350 XLT C/C PSD(for now) 4X4 LWB-White...His
01' Excursion PSD 4X4 Limited...Hers
Trucks
Sled Pull
BDS is offline
Old 05-05-2007, 01:23 PM   #2 (permalink)
Btravelen's Avatar
Re: u bolt part numbers?
A local spring shop can bend u-bolts for you.
'05 Excursion 6.0L with Air Lifts and Bilsteins, high idle mod., only 'tuner' is in the radio, towing an '00 HR Alumascape 31SKS with a Hensley.
Btravelen is offline
Old 05-07-2007, 06:58 PM   #3 (permalink)
BDS
Well, I would rather just order everything from powerstroke.com all at once...My closest spring shop is an hour away.
I did my friends F250 with the X springs/4" f350 blocks and all new u-bolts last year but I can't find the order form for the stupid bolt part numbers...
I'll just call them up.
Thanks,
Brent.
Trucks
Sled Pull
BDS is offline
