Vehicle Certification label - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 03-27-2006, 06:42 PM   #1 (permalink)
Does an '05 F250 SD that has the spring code VVFF include rear springs that are comparable to the B codes which Ex owners seem to prefer?
'04 Excursion EB, 6.0 PS, 4X4, Magnaflow Performance exhaust, Isspro gauges (boost, pyro and tranny), Bilsteins, aFe intake, front and rear leaf spring upgrade w/ bags, 30mm rear sway bar, SCT Xcal2, Red-Head box, Jordan brake controller, Arctic Fox 29V - 20,420# GCW, Everything haulin' me, the wife, the 5 Amigos, Millie and Yogi (our 2 Berners).
Stewey is offline
Old 03-28-2006, 03:50 PM   #2 (permalink)
Re: Vehicle Certification label
VVFF = V's in the front & F's in the rear.
Click here Rear Spring Thread
The F has a much higher secondary rate than the B's talked about here. The first stage is close.
2001 Excursion Limited 4X4, V10
Done so far:
Rear Hellwig (#7643),
Front Poly Frame Mount Sway Bar Bushings (Energy Suspension #4.5180G),
Gen II Landyot Radius Rods,
Rancho RS9000X's (RS99267 front, RS99266 rear),
Rancho steering stabilizer (RS5410),
Super Duty Front Bumpstops (F81Z-3020-DA)
Domelight & Foglamp overrides, Heated & Lighted TT Mirrors, Silverstars, Husky Floor & Cargo Liners, Husky molded mudflaps, V10 badges, OEM clear headlights & corners, latex tubing in door weatherstrips
U Code Front Springs (2C3Z-5310-GA),
F Code Rear Springs (6C3Z-5560-F) with added leaf from original spring pack (the 38" long leaf, 3rd from bottom, not including anti-wrap leaf)
Landyots Removed during spring change, may add Gen IV's in the future as an experiment
<span style="color: blue">2001 Excursion Pictures and Mods</span>
towrig is offline
Old 03-28-2006, 06:50 PM   #3 (permalink)
I found a set of Fs for a very good price. Do you think they would be a good replacement for the stock springs on my truck? I'm going with either Vs or Ws up front.
Stewey is offline
