Wheels for my 2000 Excursion?? Help please. - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 02-14-2010, 12:29 PM   #1 (permalink)
My friend has some wheels for sale from his 2005 2 WD Diesel Excursion....made by AVE .. 20 " (aftermarket)
Will they fit my 2000 4 WD Diesel Excursion?
TedExcursion is offline
Old 02-14-2010, 01:30 PM   #2 (permalink)
carringb's Avatar
They'll fit. But they probably aren't rated for as much weight as the stock wheels, so you'd be limited on what you carry or tow. Rating will be stamped somewhere on wheel. Usually inside of mounting flange, or on the rim inside the tire. You may be able to find spec data on the manufacturer's website.
2000 E350 DRW XLT extended wagon (yes! it's a dually!)
17" Ultra Goliath rims
Banks Powerpack, Diablo Predator
Buckstop front bumper, Reunel rear w/ 20,000# reciever
250,000+
carringb is offline
Old 02-14-2010, 01:34 PM   #3 (permalink)
For some reason, I thought something changed from 2000 to 2005 and maybe 2wd VS 4wd....not being compatable.
Thank you !!
Old 02-14-2010, 02:21 PM   #4 (permalink)
same same for X's 2000-05. Load rating and Hub or Lug centric are factor als. Make sure you have the rim checked at a wheel shop for Trueness or balance issue.
2001 X, 4x4, White, Limited, PSD,. Oil Guard, Stull 6099 Grille, AFE Intake, X Monitor, Sonnax/Tricumulator, Mobil 1 ATF w/Racor tranny filter, PHP Custom Burn Chip, Walker BTM, W Code Frt Springs, Procomp Add-a-Leaf Rear, Rancho 9000XL's w/5406 SS. Pics @ http://community.webshots.com/user/txangler32
TXANGLER is offline
Old 02-14-2010, 09:30 PM   #5 (permalink)
when they changed back to the coil springs on the trucks(03? 05?) they changed the back spacing..i would expect it would be the same for the X's..
2000 X ,4x4, DIY TYMAR, WALKER BTM, HYPERTECH LEVEL3, AIRDOG 100,
Dirtcheap is offline
Old 02-14-2010, 10:01 PM   #6 (permalink)
all 2wd have coils and all 4wd have leaf spring. this never changed 00-05 model yrs
TXANGLER is offline
