I bought the Tekonsha Prodigy Electric Trailer Brake Controller and now need to mount it in the X. Where have you guys installed yours?
Also, does anybody have a definitive use for the cubby? I was kind of thinking of mounting it there? Pros or cons, anyone?
Wayne
2004 X Limited. Medium Gray Metallic, 4x4, 6.0L Diesel, DVD, LimitedSlip Differential, HD Tow Group, Transfer Case Skid Plate, Radius Rods, Remote Starter, Magnum Hitch, Nitto Terra-Graplers, Running Boards Removed, Large Payments.
Mine came with a slide out holder which I mounted using velcro tape.
I placed it on the bottom of the dash just below the map holder pocket. The dash angle makes it just right for viewing and it is out of the way of legs and feet.
When not towing I store the unit and leave the bracket since it easily slides out of the holder.
The angle also allows the unit to hang within the specs that it is allowed to tilt without any errors.
Just in case your dash is different, 6 " to the left of the cigar lighter and about 3 " down. The special order prodigy harness hangs in the rear of the holder.
Hope this helps,
Mesu
Excursion 2004 4X4 Limited - PUEBLO GOLD - 6.0L T-C Diesel - 5-Spd Auto Trans -AM/FM Sterio In-Dash 6-CD - Rear Seat Entertainment - DVD - 2nd Row -Dual Bucket Seats - PWR HTD T-T Mirrors - 3.73LS Axle - T-Case Skid Plate - Thule Top Rack - SC Tuner
Veh. Built 7/16/03 Eng. Build date 6/27/03 by International - Purchase Date 9/1/03 Milage on date 6/9/04 = 15,000 11/15/04 = 26,890 4/19/05 = 35,639 12/12/05 = 49,810 8/29/06 = 63,750 3/27/08= 100,003 Rancho 9000 shocks F & R.
It is hard to take travel serious when every time you leave home you take an Excursion !
I have one also, the place to mount it is just below the cubby hole in the dash , you know, the rectangle one. It is a nice little indent that is made for this. Also just below the auto pedal switch. It is the perfect angle and within reach for adjustments. Have fun getting your hands in the plug in spot. [img]/ubbthreads/images/graemlins/smile.gif[/img] This place is also close to this plug in.
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium.http://community.webshots.com/user/stellinm
I put my Prodigy in the cubby. I've thought about moving it to the angled surface below the cubby, but haven't done it yet. I keep my sunglasses or cell phone in the left over section of the cubby, though I won't put the phone in there if I'm towing. A ringing phone is distracting enough without the trailer brakes locking up at the same time. [img]/ubbthreads/images/graemlins/eek.gif[/img]
Mark
''Wise men talk because they have something to say; fools, because they have to say something.'' - Plato
2001 Excursion 4x4, v-codes, Western Diesel guages, AIS with fender sleeve & zoodad, MBRP 4" exhaust, Tru-Cool Max tranny cooler, 203* thermostat, BFG AT 285/75-16's, RS9000X's, Rancho steering stabilizer, tightened steering box, Hellwig sway bar, Air-Lift springs and compressor, Draw-Tite trunnion bar WD hitch, SUVlights.com harness, PIAA driving lights with homemade harness, Cobra 25STWX radio
I mounted mine on lower edge of dash like This. I don't use my cubby for anything but a catch all, and considered installing it there, but decided I wanted it more "out of site".
Hope this helps,
Mesu
I have mine there too.I had it in the cubby also until I moved it for the XM and CB. Check my photos.
