yeah, I had yellow spots when I first bought my X... I would assume they came from some type of grease (from the factory). I took it in to the dealership and watched them use rubbing compound to remove the spots....they came right off. ( I tried several mild cleaners, and they didn't budge the spots). So, if your X is new, make them remove the spots or just buy a tub of rubbing compound.......c-ya [img]images/icons/laugh.gif[/img]
'01 X 4x4 PSD Limited White w/tan interior. Everything but video center.
I've heard that the yellow spots are rail dust which collects on the rear doors during transport. There is a procedure that dealers have to remove. I will try to find the link and post. www.autoint.com/O.E.M.%20T.S.B.'S.htm
Bob McDonald: Those yellow dots are the rear window washers spitting up. My EX is white and I had to use rubbing compound to get them off. Use white polishing compond not red (too abrasive), then a good wax. After the wax seals the paint it won't stain again. cliffsurfs
I have had 2 white Excursions(2000,2001) and they both had the yellow spots. They were from the rear washer. After the dealer replaced some part on the washer the problem was solved. I'm not sure what part they replaced but that is the problem.
2001 Excursion Limited,PSD,4X4,Diablo trans valve, 4" Cat-back exhaust,3 pillar mount Banks gauges,Fabtech 4" lift
