02 e350 7.3 no start, no crank
I have a 02 with 180,000 mi on it.
i turned it off at a gas station the other day, and when i went to crank and leave it failed. It did not crank, did not even attempt. It just clicked.
The dash appears normal, the wait to start light goes on and then goes away.
the volt meter appears weird. when you first turn the key to run it jumps to 16ish, then it falls below the 8, and then jumps back up. it will do this every time you turn the key, until you turn the key to start. then all i hear is a loud click from the starter area and a lower faster clickclickclickclick from farther forward on the engine for as long as i hold the key to start.
after this point, the batteries seem to be drained. when the key is to run, the dash lights are dim, the dinger is more of a moaner, and the stereo will not work. as soon as i hook the upper battery to a charger everything goes back to normal though.
both batteries have been tested and are good.
My only guess is a bad stater. i really dont know enough about what it takes to start a diesel to guess further. I replaced this starter about 1 year/40,000 miles ago.
i am in north carolina now, where the temps are in the 80's to 90's.
what could be draining the batteries of all their juice so quickly. IT seems like there is a HUGE bug in the circuit somewhere that is dumping a TON of energy. i keep reading about a glow plug relay, but i dont know if this applies to my situation. If it went bad, would it draw enough energy to prevent the starter from even spinning over?
