Old 05-30-2007, 12:21 AM   #1 (permalink)
'08 ford 6.0l or '08 gmc duramax
i might be in the market for a new van in the coming year and i am really torn with the decision i face.
i am in absolute love with my 2000 7.3l but am starting to flirt with 800,00 miles. the motor, turbo, tranny, injector pump and injectors are all original. i know this won't last for long but i would really like to purchase a new van, not used.
the few people that i know that have the 6.0l in their vans have been nothing but trouble and very expensive to keep running. the sprinter van is, in my opinion, a little to light and cheesey for my liking. this leaves the gmc.
do i tread to the other side?? has anyone heard much about the duramax in the vans yet?? i know that it is de-tuned compared to the motor in the pick-ups, not that that is a problem, but i am just worried about any potential mechanical problems.
i'm hoping to get some feed back before i make the jump.
2000 E-350, all stock except for a edge programer.
over 1,300,000 kms
located north of toronto, ontario
spikey is offline
Old 05-30-2007, 01:25 AM   #2 (permalink)
Re: '08 ford 6.0l or '08 gmc duramax
The current Ford vans are not available with a diesel, and the 6.0L is out of production. There is no telling if or when Ford will again offer a diesel in the vans.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 05-30-2007, 02:49 AM   #3 (permalink)
u2slow's Avatar
My Photos: (16)
How do you use your van? I thought the Duramax only went into the cargo/commercial vans.
If you are looking at them for that kind of use, cabovers with narrow box bodies are getting more common. Fuso, Isuzu, and IH/Ford come to mind.
95 F350 Crew 5spd/4.10, SuperChips tuner, solid flywheel, T444E waterpump, 205° stat, Locked F&R, 9.00R16 Michelin XLs
97 E350 SRW cutaway, E4OD/D70/4.10, 19.5s on the rear, deep trans pan, batteries inside, 1800W inverter, manual glowplugs
84 C30 Suburban, 6.2/4-spd, 3.21s
Other rigs I goof around with regularly:
93 F350 4x4, 7.3 IDI turbo, 5spd, 4.10s
90 F250 4x4, 7.3 IDI, 5spd, 3.55s
, D60 swap, straight pipe, turned up fuel screw
u2slow is offline
Old 05-30-2007, 03:33 AM   #4 (permalink)
Spikey,
I can't believe you have almost 800,000 miles on the 7.3L in a cold weather area. That has got to be a record. I love my 2000 E350SD Extended conversionvan, it's like a livingroom on the road. Did you use the Motorcraft Air Filters (Paper) or did you ever use a K&N Filter?
_________________>
A friend of mine is seriously looking at the GMC w/Duramax option, he can have the order option with driver seat delete to drop ship to a conversionvan company.
You can add mods/exhaust to the DMax no problem. And I believe he can get a dual tank on the extended model.
_______________________>
Larry Yates from Quigley Vans wrote this today on another 08 new van thread,
"To: Commercial Truck
NAFLRO
E&G
Ford of Canada
SJ: E-Series Diesel Announcement
Effective immediately, the following announcement needs to be provided to all customers, dealers, and pool accounts announcing the reintroduction of the diesel engine option in the E-Series line-up for the 2008 model year. Please use exactly this message as it has been approved by the company.
Ford Motor Company reached an agreement with our supplier to offer the 6.0L diesel engine in the 2008 E-Series. The diesel option will again be available on E350 regular length wagons, E350 vans, E350 and E450 cutaways. The diesel will not be available for production at Job #1 of the 2008 model year, August 6, 2007, as production timing is still in the planning stages. Additional ordering, scheduling and pricing information will be communicated to you as soon as it is available. Thank you for your patience.
The US dealers will receive an Electronic Dealer Notification today which contains the approved message. 2008 Order Guides and Order Banks will be available on Friday, June 1, 2007. Order Guides will include the diesel option with the disclaimer "Late Availability." We do not have exact timing on when production will begin at this time.
_______________________________
2000 E350SD PSD Extended ConversionVan, Deep Emerald Green, 3.55 LS, Premium package, Dual Alts, rear A/C. Transfer Flow rear tank (27+35=62 Gallon Range), Custom Leather Interior, LimoLights, Amsoil lubes Tranny & Rear End, Mag-HyTec Tranny and rear End Covers, K&N air filters, Alcoa 16" Rims & Michelin tires (245/75-16), CenterMatic Wheel Balancers, Autometer gauges(4), 4" MagnaFlow SS Exhaust Wrapped with Thermo-Tec Header Tape has cut the noise in 1/2, no Drone Now! , SuperChips, Bilstein Shocks, Sonnax Valve, ACPM / AIC Ford, FingerPrint Gun Safe, 20" TV Rear, DVD/VCR, 10# PowerTank (C02 AirTank), H3R Halon Fire Extinguisher 3#er. Thanks To All Members for Your Help.
AL_Fishing is offline
Old 05-31-2007, 12:42 AM   #5 (permalink)
i use AFE filters in it right now, they seem to be the same as a k&n. but i do use baldwin paper filters for when i clean my AFE's.
i also use the baldwin fuel filters and change them every 40-50,000kms.
and for the record, i also use the walmart oil filters, and canadian tire motomaster oil. change every 8-10,000kms.
as for the tranny, i use the ford filter every 100,000kms and just drain the pan fluid and replace it with the canadian tire ATF fluid. i don't fall for all of the hype for the fancy oils and filters, i just change it often.
i love watching the faces of people telling me that i should be using this and that in my van or it won't last(blow the turbo up, grind the tranny up etc.). i just tell them my mileage, then tell them to blow smoke up someone elses ass.
over 1,300,000 kms
spikey is offline
Old 05-31-2007, 01:39 AM   #6 (permalink)
blageurt's Avatar
Spikey
Where do you live ? I live in thornhill ( Dufferin/ Steeles)
My nieghbor has 900 K kms on his 95 Cube Has changed everything though.
Do you test your oil ? You never know you might hit 2 million Kms . . .
If the body is good why don't you slap in a rebuild T444E and don't look back ? Thats what I plan to do . All the other parts can be replaced as long as your body is decent. [img]/ubbthreads/images/graemlins/grin.gif[/img]
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , HD cooler , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " ,Not installed yet DP flashed PCM (60 Tow )Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is offline
Old 05-31-2007, 02:48 PM   #7 (permalink)
Spikey,
That is unreal you have oveer a million miles on your van.
Did you ever need to replace anything on the van? Turbo, tranny, whatever?
Old 05-31-2007, 04:43 PM   #8 (permalink)
My Photos: (14)
Well there is the post in the thread started by Larry Yates (Quigley) about late availability of the 6.0 for 2007.This could be possible if Ford and International have resolved their legal problems,and that Ford will end up taking delivery of the remaining 6.0 engines that were manufactured prior to 12/31/06. Since the emissions regs are by engine build date, they ramped up 6.0 production in the last quarter of 2006 to have enough engines to carry through until the '08 SD was ready. These could be put into remaining E-series 2007 production and be emissions compliant based on the engine build date.
IIRC part of the legal wrangling surrounded around Ford not paying for the remaining 6.0 production run, until IH paid their portion of 6.0 warranty claims, which IH was refusing since they didn't want to pay for claims as a result of Fords enginneering/inability to diagnose, etc and so on, the result of which in part was the remaining 6.0 and new 6.4 engines not shipped for a while.
Disclaimer: The above is my recollection of stuff read here and stuff read in Automotive News with respect to the Ford/IH debacle and as such is subject to misinterpretation, memory loss, and/or confusion of all the facts data.
The bottom line, if Ford/IH still has some 6.0's manufactured before 12/31/06 they could go into E vans for 07, but who would want one.
To the OP (Spikey), If your in need,the Dmax in a GMC looks like a good choice. I would be suspect of the trans since the Dmax vans only get a beefed up version of the 4L80E (4L85E I think its called)and take preventative steps accordingly in that regard (bigger cooler maintenance, etc). too bad GM didn't engineer it to fit the Allison Auto. The GMC van body is nice since it has a lower load height floor and larger Cargo height than the Ford. Also the swing wide hidden hinge doors are very nice, leaves an unobstructed opening for rear loading.
ddog
While I love diesels, I don't need one, and unfortunately, after much deliberation its a hobby I currently cannot afford.......... Gone but not forgotten:
1999.5 F250 CC SB XLT 4WD, 7.3 PSD, First F,2nd Diesel, nice but still liked the van better.
2003 E-350 Super Duty Chateau (Club Wagon)7.3PSD, 3rd Clubwagon,First diesel, Never should have sold it....
ddog is offline
Old 06-03-2007, 01:14 PM   #9 (permalink)
ddog
The 4L85E in the van should be OK with the standard tune of the D-Max which is considerably less than in the trucks. It's actually a pretty good trans and stands up well, even in motor home use.
Montesa is offline
Old 06-04-2007, 09:27 PM   #10 (permalink)
with all of the problems I have seen around here so far with the 6.0's..........I wouldn't even consider it.
I like the Ford vans with the diesel option........but......if I were in the market for a new van, I would go with a Duramax.
In truth though.....would rather find another '99 in good shape and just do a full rebuild on it. Actually considering doing just this on the '99 I have right now. That new Duramax engine sure is sweet sounding though.
99 7.3L PS E-350XLSD with Ambulatory roof.
(((XM))) Satellite Radio
4" turbo back Diamond Eye exhaust (portadiesel)
Pair of K&N High flow filters
HPX Hose from D.I. (blew out.....pulled it and plugged now)
In-tank and prepump mods (homemade version)
203* thermostat (dieselsite)
Tru-Cool 4739 MAX Transmission cooler (dieselsite)
Boost Relief Valve (dieselsite)
Pillar mount Di-Pricol gauge set
Sonax/tricumulator (Black Cloud)
Jody flashed econo tune PCM (DP-Tuner)
Van specific regulated fuel return (ITP)
70k miles driven annually...mostly pulling 8 1/2 foot tall 7x14 enclosed trailer
Cruise on at 61mph and 1736rpm's I don't stop 'till she needs more go juice!
stroked_van is offline
Old 06-06-2007, 10:15 PM   #11 (permalink)
fordnut350's Avatar
Glad to see that Ford is still going to produce a diesel powered E series, for now. I am part owner in an ambulance company and this is an issue that has us concerned. The Dodge sprinters seem underpowered and I have not heard to many good remarks about the GM products. It seems that this will only be temporary because I don't see how Ford will be able to cram a 6.4 into an E series. As hard as our Fords have been driven, they have not let us down yet.
2001 F-350 CC LB 4X4 06 frontend 6.5" pro-comp lift with 35" BFG muds on 18x10 Mickey T's 4" MBRP SS exhaust Airraid intake Hypetech tuner
fordnut350 is offline
Old 06-07-2007, 01:07 PM   #12 (permalink)
Ford should go back to the 7.3L engine in the vans.
Ford needs to extend the hood length a foot or two so they can fit an intercooler on the 7.3L in the van, that would be killer.
Old 06-09-2007, 08:52 AM   #13 (permalink)
I agree!!!
1999 E350 7.3psd , XLT , 15 pass/ext , purchased 6/6/05 w/255k on odo, 8/05 added BTM/straight pipe,5/06 BTS,1"shimmed front coil springs,Michelin XPS 235/85 16 R.,FredGroeske2"rear wheel spacers,1-1/2" rear sway bar,AIC,3 A-pillar guages, Tekonsha envoy,coolant filter,4 pos dp-tuner,In-tank mod & harpooned,dahl-100 prepumpfilter,Scan-guage,Bilstein shocks.
bork is offline
Old 06-09-2007, 09:24 AM   #14 (permalink)
XRACER's Avatar
That might actually be possible, if there was a shift in way the truck is 'weighed'. If it was classified by its maximum weight rather than its empty weight, the 350 series would spec out of tier II.
Tier II Standards
2005 E350 Standard Cargo Van, 6.0 PSD, 4.10 L.S., Quigley 4X4 New on 11-18-05
(seems to manufacture oil....1 Qt per 4000 miles)
Warranty Turbo 7-07 22,000 miles
Warranty A/C compressor 10-07 25000 miles
2003 E350 Extended Cargo Van, 7.3 PSD, 3.55, Quigley 4X4 New on 2-1-04
Some Pix
Transfer Flow 46 Gal.***Delaminated***Replaced 8-29-06 UNDER WARRANTEE
XM Radio, Alpine GPS Nav. System
7.5' Western Snow Plow
Quad Captain's chairs and Espar Furnace
OX cable locker on front
ARB locker on rear
BTS Tranny 9-29-07 @55,000 miles
Aluminess Bumpers
Mile Marker 12,000 pound hydraulic winch
2000 F250 ...... just cuz people are dumping them for the fuel bill. Got mine on ebay for $8749 with 116K on the clock. Go-fast mods to follow.....
XRACER is offline
