1990 E350 Club Wagon: Location of A/C recharge port? - Diesel Forum - TheDieselStop.com
Old 04-13-2008, 01:37 PM   #1 (permalink)
My Photos: (18)
Question 1990 E350 Club Wagon: Location of A/C recharge port?
Just got the thing.... 1990 Club Wagon E350 w/ 7.3L IDI. I'd like to put/test the AC refrigerant. It doesn't seem that cold. The A/C compressor runs (thankfully), but it doesn't blow cold (well, what I consider cold).
It's been converted over to R134A (sticker is there) and I found a red capped port. It was by the driver side batter, right over the windshield fluid bottle. Any how, I'm hazarding a guess that that is the high side port. I've been told that one should find the low side port to recharge. So... question is, where is it? I was assuming it should have a blue cap, but who knows if it was put back.
I looked at the Chilton/Hanes(?) and it give a cop out answer. Says to go to a professional . It doesn't even show pictures of the inside of the engine for locations of stuff.
So where is the port to recharge the AC system located at????
THANKS!
edit-
Oh, other question. On the fuel filter housing, the bottom has a what appears to be a barb fitting. I take it that is the drain. Any how, is there suppose to be a hose attached to it, mine is doesn't have one. And where does this hose lead to (if it is suppose to have one)?
1999 E-350 Cub Wagon, 7.3L Power Stroke, E4OD, 3.55
1990 E-350 Club Wagon, 7.3L IDI, E4OD, 3.54LS x2
1983 F-150 2x4, 4.9L, C-6 w/GV-OD, 3.55 Farm pickup
1981 C-8000, 3208 CAT, RT-6510, Rockwell SSHD Tandems (Swap)
1977 K100C, NTC-350, RT-1110, Tandem
1977 Transtar II, NTC-290, RT-9509 Single
1977 Transtar II, Formula 290, RT0-9513, Tandem
1974 C-750, 391CID, Clark 5 speed, Eaton 2 speed
Kaliburz is offline
Old 04-13-2008, 03:23 PM   #2 (permalink)
van_350sd's Avatar
My Photos: (80)
I just took mine to a pro shop, it's way over my head.
Our vans take 4 lbs. of the 134A for a Front % Rear system and 13 oz. of Pag Oil.
That's what my sticker says under the hood.
My system was only holding 1/2 lb. I had to add 3 1/2 lbs. of 134A.
It cost 200.00, kinda high, but the van is blowing 42 degrees in the front and 43 in the rear on a hot day.
2000 E350-Super Duty-ExplorerExt. Mobile LivingRoom-7.3LPSD-3:55LS-Dual AmsoilEaA Air Filters-AutoMeter Phantom Guages-Pyro(Pre)-Boost-Tranny+Hobbs Hour Meter-C2 Pyro(Post) WaterTemp - 4"SS MagnaFlow Wrapped w/ Thermo-Tec 2" Header Tape-SonnaxValve+Tricumulator Shift Springs-Mag-Hytec Tranny+Rear End Cover-1 UpFront Spring Option-Bilstein's-Centramatic's-35 Gallon MainTank+TraxII TransferFlow 27 Gallon Aft.Aux.Tank=62 Gallon Range-ACPM/AIC-DualBattery+Alt-450 FilterMAGx2-Fumoto-ALL Amsoil-Bob's 203*&Billet Housing-Alcoa Classics-Explorer Conversion Installed DynaMat Complete Interior - 4 Leather Captain Chairs/BackSeat/Bed-Hellwig Sway Front/Rear-48"Hi-Lift-C02PowerTank5#SnapOn1/2"ImpactMG725-H3RCleanAgentHalotron2.5#
van_350sd is offline
Old 04-13-2008, 05:14 PM   #3 (permalink)
My Photos: (18)
Ah... but where is the port????
Kaliburz is offline
Old 04-15-2008, 12:51 AM   #4 (permalink)
My Photos: (18)
OKay, I found the port. Kind of a weird location. It would be right above the alternator, on the section of tubing that runs from the driver/passenger side. It's behind a plastic piece that a bunch of stuff is in (battery cable, vacuum lines and a wiring harness). Not exactly in view.....
A mechanic buddy took out his little mirror on a 'stick' and searched.....
Kaliburz is offline
Old 09-24-2009, 06:20 PM   #5 (permalink)
van_350sd's Avatar
My Photos: (80)
Threads from the Past...
So if you find the Port can you simply hook-up-a can of Refrigerant and just fill-er-up?
I don't, want to pay 200.00 again.
Old 09-24-2009, 06:38 PM   #6 (permalink)
chuckster57's Avatar
That's one way of doing it, but you risk the chance of overcharging and ruining the system. The Proper way would be to hook up a manifold gauge set to see what the high and low side pressures are, and based on the readings you can make a pretty educated guess as to what is wrong. Those recharge cans at wally world and such have a generic "gauge" on the top based on an average of what the low side reading should be.
If you were in my area it wouldn't have cost you $200.00....But then I'm part of the underground economy
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is online now
