Old 02-15-2009, 12:27 AM   #1 (permalink)
laz
1990 e350 overdrive light blinking
When towing to the race track this morning I noticed the overdrive light flashing after locking the trans in 2nd to get up a steep grade. Surely the blinking means something is wrong. Is there a specific thing? All the advice I've found thus far is to pull codes, but I don't think my 1990 7.3 IDI is that fancy.
If the light just means that overdrive doesn't work ... that's not the end of the world, since my ambulance almost exclusively tows.
The ambulance also spit out the alternator and power steering belt, luckily when I got close to my destination. No alternator belt means no power brakes, which means 2 feet required to stop the behemoth. The belts were lost after the blinking started, but I guess it could be related. I put new belts on in the dark and cold tonight. At least it wasn't raining
help?
laz is offline
Old 02-15-2009, 12:39 AM   #2 (permalink)
chuckster57's Avatar
E4OD is computer controlled and if the OD light is flashing then it means there is probably a trouble code set. Your truck is OBD I and if you have an OBD I scanner it will give you the codes. If you don't have a scanner you can get the codes with an ANALOG volt meter. Just follow the directions in the link:
Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
1994 F-350 7.3 IDI Turbo, crew cab, E4OD, LB, Dually Photos
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
chuckster57 is offline
Old 02-15-2009, 02:54 AM   #3 (permalink)
My Photos: (28)
Then again it could be the wire that is in the shaft... at the end it likes to break. I know that I had that fun a few years ago on my 2000 E350.
Just a thought.
IT IS MINE ALL MINE.....(The Van that is, it has been Released by Lenholder)
It is a Very wet fall. Might need Hip waders. Next on the list is Snow, and that could be any day.
2000 E350 7.3PSD, Hellwig Stablizer bar, Headlight Harness upgrade 265/75/16E, 140 Lightforce w/blue, yellow, clear covers. My Photos http://photos.thedieselstop.com/showgall...&stype=&ppuser=
"FAILURE IS NOT AN OPTION"
Alaskapsdvan is online now
Old 02-24-2009, 02:24 PM   #4 (permalink)
cdnsarguy's Avatar
My Photos: (79)
Visit my photo link the trans codes for the E4OD are there....
93 F250 7.3 IDI S/C XLT 4X4 E40D 3.55LS, Captains chairs, Tutone Mocha, Leer 48" Hiboy cap, FR & RR hitches, full DeeZee running boards. Factory ordered/delivered Jan 93 has 200K miles 01July09.
Toys: 2006 36' Triple E Embassy coach (powered by Cummins), 18' Sylvan Pro Fish with Mariner motors.
Proud Canadian BOOB man too!!
cdnsarguy is offline
