1993 E350 starting problems - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 05-27-2007, 05:57 PM Thread Starter
First post and I am already asking for help.
I have 2 1993 E-350 Ambulances that I take care of and both have had the same dang problem in the same week.
They start fine and then after running for 20-30 minutes, get shut off and sit for 10-45 minutes. When the crew trys to restart it, it cranks and cranks but will not start. Checked fuses, then opened injector lines and I am getting no fuel at the injectors, no smoke out the exhaust.
Last time one went to a shop and the next morning when they got to look at it, they had no problems, started and ran fine. We picked it up and used it for two days with no problems. Now our other ambulance does the same darn thing less than a week later.
These are used rigs that we have had since January, so I have no history on them.
One messing up is bad both doing it in the same week is horrible.
Anyone have any suggestions?
Thanks,
Jason
tattoo13 is offline
post #2 of 4 (permalink) Old 05-27-2007, 07:52 PM
Re: 1993 E350 starting problems
I believe that the injection pumps are worn out. When you shut off the motor, the IP heat soaks which expands the metal in the pump and increases the internal clearances. Then the fuel bypasses the plungers and there is no injection pressure.
There is a test - when the truck will not start, pour a pan of "room temperature" water over the IP which will cool it down. Then try to start. Do not use cold water as it can cause physical damage to the IP.
1997 Ford F350 SRW 7.3L PSD
1985 Ford Ranger 2.3L 5 speed
1966 Mustang 200 I6, auto, 4 wheel disk, power brake retrofit, Corvette master.
Former vehicles, 1994 E350 7.3L IDI, 1985 International 1654 rollback, 6.9L IDI, (2) 1994 Ford E350 7.3L IDI, 1985 Ford F350 DRW 6.9L IDI, 1985 Ford F350 wrecker 6.9L IDI.
*dual ASE Master Certified, Automotive, Medium & Heavy trucks*
Owner / operator, Patriot Automotive, N Ridgeville OH
Mr_Roboto is offline
post #3 of 4 (permalink) Old 05-28-2007, 03:09 AM
Wasn't it a bit strange it happened more or less the same day?
Are you sure the fuel you have used have good quality? Some stations may serve you water or microbes from the pump.
E350 '93 7,3 Diesel IDI/NA E4OD RABS II Oslo Norway
200 000 km and counting
SAAB 900 '91 160.000 km
SAAB 900 '83 300.000 km sold
VW Caravelle TD '88 40mpg fully loaded(sold)
Citroen BX 16 (crashed (not by me))
Misc American leftover: Diamond ('46), GMC('49), Dodge ('49)
Torstein is offline
post #4 of 4 (permalink) Old 05-28-2007, 04:10 AM
cdnsarguy's Avatar
My Photos: (109)
Check the fuel for Gasoline if they both filled up the same day same location.........
What is the mileage on the vehicles/IPs, done any other work on the engines fuel filter Xchange etc...
You must know about...this site by now........I post it often.
http://www.intellidog.com/dieselmann/idi.htm
Proud Canadian BOOB man too!!
cdnsarguy is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > E-Series Vans
