1998 E-350 Powerstroke 7.3L Diesel Coolant change - Diesel Forum - TheDieselStop.com
Old 09-16-2009, 03:57 AM   #1 (permalink)
Unhappy 1998 E-350 Powerstroke 7.3L Diesel Coolant change
Hi,
I bought a 1998 Ford E-350 7.3L Powerstroke Diesel. My coolant level in the reservoir is low.
I was wondering whether I should Flush & Fill completely OR
purchase a gallon of the International's Fleetrite ELC and top it off in the reservoir.
Note: I am a rookie in the world of Diesels, please advise step by step.
phillydevil is offline
Old 09-16-2009, 06:38 PM   #2 (permalink)
blageurt's Avatar
I would buy some coolant test strips from Napa or elsewhere and test it to see where you are. Then , I would add 50/50 Prestone green coolant , or whatever you like as long as it's rated for our trucks and add 1 bottle of the Ford coolant additive , retest and do what you have to do to keep it in spec . . .
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " , DP flashed 60 Tow , 140 V idm , Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K , Timbrens SES kit , replaced lift pump /ICP/ IDM @ 256 K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is offline
Old 09-16-2009, 09:05 PM   #3 (permalink)
SIC-E's Avatar
if wanna flush, there are good write ups here. just do a search.
2004 E450 Cutaway, 6.0L, quigley 4x4, ambulance pkg., maxbrake controller, curt 20k fifth wheel. Future mods: 52" sleeper, tandem (6x6?) rear (aint look'n likely), frame cover. maybe a Herd front bumper.
2003 E350, 7.3l, x-cargo
2003 F350 Lariat, 4x4, CC, SRW, Dark Green Fx4 SOLD
1995 C3500 6.5l work trk, 2x4, CC, DRW, white DECEASED PREMATURALLY
2003 JEEP WRANGLER, ooooops, not anymore!
1986 26' Seaway Northstar w/ 454 Mercruiser
2008 Montana Mountaineer 332PHT
1991 GMC Topkick, CAT, 4' vert. gang boxes, 12' dump. if only all were as reliable!
SIC-E is offline
