I just bought a 1999 Extended PSD Cargo, and I have a few questions. My first question is did these vans come with catalytic converters? next the heater/AC control fan only works on high wheres the resistor that everyone talks about and what size do i need? My 93 van has a block heater but I cant seem to find one this van. I haven't really looked into it but the power mirrors dont work, it maybe a fuse but I havent checked anything out. Any ideas? The last thing is the rear dome light doesnt work but the one up front does?
You could change the whole blower, but I'm pretty sure the resistor pack from Ford is under $15. I think you pull the blower, switch the resistor pack, then put back in.
I'm not sure about the block heater. Hopefully someone else will chime in.
And no, I don't think they came with a catalytic converter.
Thanks for your help, I went out and fixed the light just now you were right the switch had popped off the contact point. Ill go down to the ford dealership and order the resistor pack.
Block heater is in the oil filter / oil cooler assembly underneath the drivers side floor attached to the side of the engine . Just look at the oil filter and its above it. If you are missing the cord it is cheaper to buy the kit from Ford or these guys . . . Your Premiere Source for Ford Truck Parts and Accessories
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " , DP flashed 60 Tow , 140 V idm , Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K , Timbrens SES kit , replaced lift pump /ICP/ IDM @ 256 K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
