are 2 batteries really necessary? - Diesel Forum - TheDieselStop.com
Old 03-04-2007, 09:20 PM   #1 (permalink)
My Photos: (9)
Hey all, I haven't posted in a while. Hope everyone's ride is doing well.
I have only one battery installed in the 88 7.3 E350 and it never failed to start this winter. I'd wait for the wts light to go out and within 1/4 second of cranking it would fire right up and idle smoothly. The coldest I've started it was 9 F. I installed a reman IP and new injectors last summer and I'm sure that helped but, are 2 batteries really necessary? [img]/ubbthreads/images/graemlins/ooo.gif[/img]
88 E350 7.3 C6 154k
done: Remanufactured Inj pump, New Stanadyne injectors, Michelin M/S tires, ShellZone AF & Fleetrite SCA, replaced and relocated fuel filter assembly, elec fuel pump, no flying saucer, return lines/ o-ring kit, new heater core, 8 Beru glow plugs, oil & filter, stabilator on sliding door (plastic slider cracked in half)
Hot compression readings:
2. 500 1. 500
4. 460 3. 420
6. 540 5. 465
8. 480 7. 540
to do: transmission fluid, fix rust spots, WVO conversion.........
nubiecanobie is offline
Old 03-04-2007, 10:24 PM   #2 (permalink)
Re: are 2 batteries really necessary?
Ford (or any automaker) will not spend a dime that is not necessary. That includes your second battery.
Whether or not there will be negative consequences to running with only one battery is hard to say.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 03-05-2007, 09:42 AM   #3 (permalink)
Super_Dave's Avatar
I agree. But I did run a couple weeks in the summer with only one battery waiting for another to arrive at the place I get my batteries from.
Super Dave
2006 E350 6.0PSD
2003 Excursion Limited 4WD 7.3PSD - Sold
1996 E350 Super Duty bus 7.3PSD - Sold
Super_Dave is offline
Old 03-05-2007, 10:00 AM   #4 (permalink)
If the engine doesnt start right away or glow plugs stay on too long, I would think the amp drop would cripple you quickly. I used to run the little lawn tractor battery in my race boat (weight saving)But if it doesnt start right away, your stuck. Also, I wander if the starter would get a little hotter quicker with reduced amps/volt drop?
1999 E350 7.3psd , XLT , 15 pass/ext , purchased 6/6/05 w/255k on odo, 8/05 added BTM/straight pipe,5/06 BTS,1"shimmed front coil springs,Michelin XPS 235/85 16 R.,FredGroeske2"rear wheel spacers,1-1/2" rear sway bar,AIC,3 A-pillar guages, Tekonsha envoy,coolant filter,4 pos dp-tuner,In-tank mod & harpooned,dahl-100 prepumpfilter,Scan-guage,Bilstein shocks.
bork is offline
