2012 Van Year Engine Mileage Diesel/Gas Check - Diesel Forum - TheDieselStop.com
Old 12-30-2012, 02:32 PM   #1 (permalink)
van_350sd's Avatar
My Photos: (80)
This is a thread to see how well people are doing with the vehicle,
How many miles you may have and what kind of major repairs have you had to do?
Year Mileage:
2000 E350 7.3L and I just turned over 20,000 miles. Low miles I know, my van still looks and runs like new thanks to no salt in Florida on the roads. All I had to replace is a Starter so far.
Oil You Use:
I'm running the T6 Full Synth Oil changing every 3-5k.
Current Diesel/Gas Fuel Price:
Hess Gas Station Diesel 3.84
Any Major Repairs:
How Long to you Plan on Keeping it?
The way I take care of my van I can easily see another 20 years of service life from it.
I'm interested to hear how many miles some of the higher mileage 7.3 vans have.
You can copy/paste to do it quickly.
Happy New Year, Over the Cliff...
2000 E350-Super Duty-ExplorerExt. Mobile LivingRoom-7.3LPSD-3:55LS-Dual AmsoilEaA Air Filters-AutoMeter Phantom Guages-Pyro(Pre)-Boost-Tranny+Hobbs Hour Meter-C2 Pyro(Post) WaterTemp - 4"SS MagnaFlow Wrapped w/ Thermo-Tec 2" Header Tape-SonnaxValve+Tricumulator Shift Springs-Mag-Hytec Tranny+Rear End Cover-1 UpFront Spring Option-Bilstein's-Centramatic's-35 Gallon MainTank+TraxII TransferFlow 27 Gallon Aft.Aux.Tank=62 Gallon Range-ACPM/AIC-DualBattery+Alt-450 FilterMAGx2-Fumoto-ALL Amsoil-Bob's 203*&Billet Housing-Alcoa Classics-Explorer Conversion Installed DynaMat Complete Interior - 4 Leather Captain Chairs/BackSeat/Bed-Hellwig Sway Front/Rear-48"Hi-Lift-C02PowerTank5#SnapOn1/2"ImpactMG725-H3RCleanAgentHalotron2.5#
van_350sd is offline   Reply With Quote
Old 12-30-2012, 04:20 PM   #2 (permalink)
carringb's Avatar
Well mine's not a 7.3L but the title says diesel/gas check....
-343,400 miles.
-0w40 Liquimoly synthetic every 8-10,000 miles, Napa Platinum filter
-Regular unleaded $3.20-$3.30
-Major repairs:
1)Radiator @ 275k and again at 335k because the replacement was dumping ATF into the coolant
2) Ring & pinion @ 180k (broke a tooth of the pinion), then the carrier at 305k because it split in half
3) A couple fender mounted starter relays, and more recently the starter solenoid.
4) Few weeks ago replaced the #7 coil pack.
5) new windshield every spring due to the amount of driving in the mountains.
And no rust on mine, since Oregon does not use salt on roads.
Plan in keeping it for a while still. Hoping make it to 500,000 without any major repairs, but I'm already planning on replacing the other 7 coils. I suspect they aren't far behind.
2000 E350 DRW XLT extended wagon (yes! it's a dually!)
17" Ultra Goliath rims
Banks Powerpack, Diablo Predator
Buckstop front bumper, Reunel rear w/ 20,000# reciever
250,000+
carringb is offline   Reply With Quote
Old 12-30-2012, 04:45 PM   #3 (permalink)
blageurt's Avatar
My Photos: (9)
425,625 kms
Rotella regular every 8-10 k kms
Fram / Motorcraft oil filters
Racor /Napa Gold Fram Fuel Filters replaced as per Severe Service Schedule....
2nd HPOP , Third IPR , Second ICP, third MAP, second EOT
Injector O-rings, 3 Cam sensors, 2 VSS sensors, 2 Solenoid Tranny packs, third E4OD Transmissson....
Second Turbo, Second Engine Wiring Harness, third set of UVC harnesses and Gaskets
4th IDM
2nd set of Glow Plugs, 4th GPR
Third Starter
Second Complete Front End
Second Water Pump and Heater Core
Fourth Set of Brakes 3 Front (including calipers) Second rear ( complete including Drums / wheel cylinders / E- brake cables )
Body is rusting Slowly thanks to Krown Rust Control| Rustproofing and Protection for Cars, Trucks, Vans
Many Sets of Tires
All side markers / tail lights replaced at least once
Third Brake Light replaced twice
Rear Bumper twice
2nd Wiper Motor , 2nd Multifunction Switch , third Light switch, third Heater switch and Motor
Modest Body Work done here and there due to rust
Side Barn Doors replaced with Southern US Rust Free doors
Diesel Here is 1.15-1.25 CAD per Litre..( 3.785 litres = 1 US Gallon )
Thats all I can think of for now
Runs like a Beast....oil tests come back like new every time
It will still be running when I will be taking the "dirt nap "
Best Truck I have ever owned....
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D60FF, EBPV Delete , DP flashed 60 Tow , 140 V idm , Autometer Triple pod , Michelin LTX
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 , MSD IGN , Custom C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
blageurt is offline   Reply With Quote
Old 12-30-2012, 06:33 PM   #4 (permalink)
MikeL46's Avatar
My Photos: (14)
106K miles
T-6 every 7500 miles
Amsoil dual remote oil filter system. Donaldson filter/Amsoil bypass filter
Diesel fuel $3.89
3 injectors replaced
Transmission case, reverse gear
2 Alternators
Turbo and 1 blue rubber boot
EGR valve
Tires last ~65K
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
106345 miles. 16.65 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
MikeL46 is offline   Reply With Quote
Old 12-30-2012, 06:59 PM   #5 (permalink)
My Photos: (18)
Year Mileage:
1999 E350 7.3L with 244,xxx miles. (Bought at 214,xxx)
Oil You Use:
Delo 15W-40
Wolf Den- Diesel 3.75
Any Major Repairs:
This year- A/C line rubbed on engine oil fill bracket.
A while...
1999 E-350 Cub Wagon, 7.3L Power Stroke, E4OD, 3.55
1990 E-350 Club Wagon, 7.3L IDI, E4OD, 3.54LS x2
1994 Chevy C2500 6.5L TD, 3.42
1983 F-150 2x4, 4.9L, C-6 w/GV-OD, 3.55 Farm pickup
1981 C-8000, 3208 CAT, RT-6510, Rockwell SSHD Tandems (Swap)
1981 VW Rabbit Pickup 1.6L diesel (project)
1978 VW Rabbit 1.5L diesel (project)
1977 K100C, NTC-350, RT-1110, Tandem
1977 Transtar II, NTC-290, RT-9509 Single
1977 Transtar II, Formula 290, RT0-9513, Tandem (project)
1974 C-750, 391CID, Clark 5 speed, Eaton 2 speed
Kaliburz is offline   Reply With Quote
Old 12-30-2012, 08:56 PM   #6 (permalink)
dieseldude73's Avatar
Year Mileage:
1999 E350 Clubwagon, 170,900 miles (V10, carringb just made them sound so appealing)
Oil You Use:
Castrol (But I haven't had it long enough to change the oil yet!)
QT regular unleaded $3.09
Any Major Repairs:
Lots of little stuff, refreshed brakes & suspension
Until gasoline becomes unavailable or once the Legacy Ford parts guys start calling my parts superceded, obsolete, and unavailable.
'96 E350 aka Vanna White, decommissioned @ 380k miles
'99 E350 Clubwagon, V10, 172k miles
'98 F150 Bi-fuel CNG, 184k miles
'06 Dodge Charger Daytona R/T, for my doppelganger, 72k miles
dieseldude73 is offline   Reply With Quote
Old 01-16-2013, 05:33 PM   #7 (permalink)
Year Mileage:
2005 E350 club 15 pass 59,000 16-17 winter 19-21 summer mpg
Oil You Use:
Delvac 15-40 5-6k
Current Diesel/Gas Fuel Price: 3.85
Any Major Repairs:
3 turbos first 18k and 1 egr valve under waranty
50k- heads decked, arp's egr delete, new dummie plugs, turbo oil drain,
STC fitting, blue spring, Straight pipe, vacuum pump, oil cooler, cleaned turbo, ball joints, and sct innovative.
Till the body falls off the frame.
ciuf is offline   Reply With Quote
Old 01-17-2013, 11:12 AM   #8 (permalink)
edwardsjr1's Avatar
2003 E350 Extended Cargo
7.3 with 237K
Bought at 235K
New pedal assembly when purchased.
Transmission replaced at 214k (receipt found in owners manual!)
Cheapest Oil I can find every 5K (only have done one oil change so far)
Diesel price: 3.79
I will keep until I buy a 99-02 7.3 Truck.
edwardsjr1 is offline   Reply With Quote
Old 01-17-2013, 03:03 PM   #9 (permalink)
03 7.3 now at 220000 or so and mine since day 1.
Rotella every 5 to 8k. Fresh trans fluid every and gear oil too.
Spanked at the pump every time. Remember when diesel cost less than gas?
Repairs:
Accel pedal due to idle confirm switch failure
Third Vac Pump - I hate that junky part.
Second Alternator
New PS Pump
New idler pulleys or bearings
HPOP seal failure repair
Water Pump, T stat and fan when I did the HPOP at 200k, just because.
Tie rod ends
Front wheel bearings
Rotors and brakes
New windshield, twice, because I can't seem to miss a rock from a truck.
I will keep this super duty until it rots out and just won't go anymore. It is the best van I have ever had.
Dave
2003 E350 Chateau, last of the 7.3 Turbos
www.divehatteras.com
DivinDave is offline   Reply With Quote
Old 01-20-2013, 10:28 AM   #10 (permalink)
jgorm's Avatar
2004 E450 7.3L
~39,000mi
Purchased at 33,000mi
No issues for me so far. It could use a bit more power pulling the 13K lbs up the large grades. Someday I'll fab up an intercooler and add some fuel!
E450 7.3 PSD in a Bigfoot 24' motorhome.
Acquired parts for the intercooler mod
Intake spider
jgorm is offline   Reply With Quote
