2nd battery Relocate - Page 2 - Diesel Forum - TheDieselStop.com
Old 05-25-2009, 05:59 PM   #16 (permalink)
van_350sd's Avatar
My Photos: (80)
Alaska,
This gent makes some of the best cables available.
What size cable do you need
I have 3 batteries, in my 2000, The 2 stock batteries one under the hood, and the one on the side rail frame, then the 3 rd. is 3 feet over on the fdrame, almost under the passenger seat area.
If you put the batteries in the rear of the van, get the largest ones you can afford.
The 2/0 is great stuff, but the 3/0 is worth the extra money, not much more with this gent.
2000 E350-Super Duty-ExplorerExt. Mobile LivingRoom-7.3LPSD-3:55LS-Dual AmsoilEaA Air Filters-AutoMeter Phantom Guages-Pyro(Pre)-Boost-Tranny+Hobbs Hour Meter-C2 Pyro(Post) WaterTemp - 4"SS MagnaFlow Wrapped w/ Thermo-Tec 2" Header Tape-SonnaxValve+Tricumulator Shift Springs-Mag-Hytec Tranny+Rear End Cover-1 UpFront Spring Option-Bilstein's-Centramatic's-35 Gallon MainTank+TraxII TransferFlow 27 Gallon Aft.Aux.Tank=62 Gallon Range-ACPM/AIC-DualBattery+Alt-450 FilterMAGx2-Fumoto-ALL Amsoil-Bob's 203*&Billet Housing-Alcoa Classics-Explorer Conversion Installed DynaMat Complete Interior - 4 Leather Captain Chairs/BackSeat/Bed-Hellwig Sway Front/Rear-48"Hi-Lift-C02PowerTank5#SnapOn1/2"ImpactMG725-H3RCleanAgentHalotron2.5#
van_350sd is offline
Old 05-25-2009, 09:39 PM   #17 (permalink)
My Photos: (35)
The job is already done.
I did use the 2/0 cable from the front to the back, and that was bigger than the Ford cable that I pulled out of van.
Later I might pull the front battery and put it in the back with the other one and wire them together and have just the crimps in the front for jumping if needed..
One of the main reasons for the relocation of the second battery was that I just got sick of dealing with the thing under the van, there was no easy way of checking it like the front or now the relocated battery, with out making it 1-2 hour B.S.
Winter is here again, and yes I mean WINTER.. the temps are likely to reach -25F and then there is the snow and the dark.
2000 E350 7.3PSD, Hellwig Stablizer bar,140 Lightforce with covers, 55Watt High/Lows HID's , extras in the bumper. 4"Aero Turbin and 4" all the way back. 1705 program, Scangauge II,265/75/16E Toyo Open Country, My Photos http://photos.thedieselstop.com/showgall...&stype=&ppuser=
"FAILURE IS NOT AN OPTION"
IT IS MINE ALL MINE.....(The Van that is, it has been Released by Lenholder)
Alaskapsdvan is offline
