What are my options to get a 4" turbo back installed on my 03 7.3. I don't think anyone sells an off the shelf kit. Can I buy one for an f-series and modify it to work? What would I have to modify?
dennis at ITP sells a 4'' diamond eye aluminized system for the van.
Wade
2002 E350 EXT. Cargo 7.3PSD , silver metallic , bought new presently 240K , dual alts. , auxiliary idle control , rear a/c heat , premium group , michellin LTX M/S on AMERICAN RACING WHEELS outlaw II's , centramatic balancers , wal-mart everstart maxx , AIH delete , Evans coolant conversion , 203 degree thermostat , ITP in tank mods van specific , ITP prepump filter,ITP regulated return system van specific , ITP valley line kit ,Beans stage one single shots , DP-TUNER F5 custom tunes for singles , stock,drive through,40 tow,80 econo,120 extreme,tables raised so i don't set codes overboost etc. , NON-EBPV turbo pedistel DIESELSITE viton o-rings ,paper filters temperarily until i devise a better set up , 4'' exhaust on way
I bought a complete 4" DP/exhaust (alum) system here...fit and install went fine...all brackets and hangers using stock locations...some others have bought here too...I had good experience working with them...very reasonable ...
Give Dennis a call @ ITP he has a VERY NICE 4" system for you 03, 7.3L
The set I got from Dennis was so simple my Grandson had it laid out on the Garage floor when I got home the day it arrived.
The whole job took about 2 hours at a local muffler shop to weld up. [img]/ubbthreads/images/graemlins/cool.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
2003, E-350, XLT, Chateau, 7-Pass. Club Wagan, 7.3L PSD, 3:55 LS Rear, DP TUNER F-5, AMSOIL TS-126 Air Filter, Fleetguard LF-9027 Bypass Oil filter, Sirius Satellite Radio, Garmin GPS, SuperCrewzer, AutoMeter (Pyro. Trans. Boost)Gauges, 4" Diamond Eye Turbo Back Exhaust, Sonnax valve & Tricululator springs, PML Alum. Tran's Oil Pan, Tru-Cool 4739 Tran's Cooler, ScanGuage Monitor, DAHL 100 Fuel Filter, "Last of the 7.3's".
USMC-(Ret).
You Can't Always Get What You Want, But If You Try Some Times You Just Might Find, YOU GET WHAT YOU NEED.
IF you want stainless, you have to use an F series system for a 99-03 7.3 and modify it. To use an F-series exhaust on a van, you have two options.Buy a Van turbo adaptor (VTA) this part allows truck guys to use van turbos. It allows you to use a truck downpipe (Flange at turbo is larger on a truck). The other option is to cut the flange from your stock van down pipe and weld it to the new F series system down pipe.Depending on brand the down pipe may also need a little tweaking. This only applies if you want stainless exhaust.
Your other options for van specific exhaust were previously listed, they are both aluminized systems, but should hold up well. The link for ITP if he still has them is www.itpdiesel.com The van part has been permanently "under construction" since he re-did the site(limited demand)so you may have to call him anyway.
ddog
While I love diesels, I don't need one, and unfortunately, after much deliberation its a hobby I currently cannot afford.......... Gone but not forgotten:
1999.5 F250 CC SB XLT 4WD, 7.3 PSD, First F,2nd Diesel, nice but still liked the van better.
2003 E-350 Super Duty Chateau (Club Wagon)7.3PSD, 3rd Clubwagon,First diesel, Never should have sold it....
Do I want a 3.5 or 4" downpipe? Mods will be the exhaust, dp tuner, and perhaps water/meth in the future. I would imagine I will be running the 80 econo tune 99% of the time and maybe get the 120 race just for the hell of it.
http://www.warpspeedperformance.com/ comes with a 4 inch downpipe. HOWEVER when mine was installed, it was so tight that the pipe hit the bellhousing or something under there. The shop had to heat the pipe and put a "dimple" in it to clear the part and stop the vibration. No other problems other than the muffler that came with it still has some "drone" to it at hwy speeds.
1998.5 E350 7.3 extended cargo with Late model doors ,po.wer windows, locks and mirrors.Isspro gauges from DPPI, Power Slot Cryo rotors from DPPI, Hawk LTS from DPPI,NAPA DOT 4 brake fluid,NAPA calipers,Evans coolant,Dieselsite ac control valve,Dieselsite 203* thermostat,BTS valve body, Amsoil tranny fluid,4WD deep tranny pan from Dieselsite, DieselSite transmission bypass filter,Amsoil dual oil filter, Amsoil 15-40 wt oil,4 inch Warpspeed Performance exhaust,Thermo-Tec Exhaust Insulating Wrap, Bilstein shocks,Line-X 2-06-2009 103,400 miles following added Beans stage II single shot injectors, Air Dog, Beans regulated fuel return with fuel bowl delete, glow plugs and Stancor gp relay, Beans modified IDM, Stealth HPOP stage I, Dominator 66 turbo, DpTuner reflashed factory pcm that was split shot injectors to the single shots, 9 tunes from DP Tuner including decel tune,tuflocs on all doors, Snow water-methanol injection stage 3 installed by Beans Diesel, BTS tranny
