Old 08-21-2003, 09:56 AM   #1 (permalink)
My Photos: (9)
4EOD ATF capasity
Hi,
my book says that the 4EOD tranny takes abt. 16 qts ATF, is that correct?
Might change to synthetic soon, -never drained any automatics before and got a bit surprised by the high volume on this one...
-Ray.
1994 E350 Custom Line 7.3IDI, E4OD, 2WD Limited Slip, 4wheel ABS, K&N air filter, 3rd owner, 130K miles on the clock
ACCN - American Car Club of Norway Member no. 263314
My Photo Gallery
RayHell is offline
Old 08-21-2003, 01:07 PM   #2 (permalink)
Re: 4EOD ATF capasity
Sounds about right,
I just changed mine and drained the converter as well. I used a case and then some to fill it back up, I guess it was 14 to 16 quarts. I used an old Igloo beverage ice chest to drain mine in, they are relatively low and large enough to catch everything. You will need some oil dry though, I always seem to dump a quart or so somewhere in the process. I also pulled the cooler lines loose and blew them out, made a heck of a mess but feel good that I changed almost all the fluid. Went back with regular Dexron ATF, figured this tranny will need a rebuild someday soon (200K plus, you tell me?) so why waste the high dollar synthetic.
1999 F-350 crewcab 4x4 SRW (former 4x2)
2000 F-350 reg cab 4x4 dually
DieselDeaf is offline
Old 08-21-2003, 01:28 PM   #3 (permalink)
Have you tried THIS ? I've used this procedure. It works real well.
Casey_1 is offline
Old 08-21-2003, 05:00 PM   #4 (permalink)
My Photos: (5)
Dexron ATF
I did not realize that our E4OD trannys are GM. My manual states that the E4OD takes Mercon transmission fluid.
1991 Ford PL Custom Ambulance Type III 7.3L Diesel. Photo Here Pioneer AM/FM/XM/CD Stereo. Code 3 lightbar, Whelen Strobes and flasher lights. Whelen flood lights on front, rear and sides. There bright enough to turn darkness into daylight. Siren with several tones plus electronic airhorn and PA. Custom 3" exhaust from manifolds back with a Gibson Superflow Muffler [img]/ubbthreads/images/graemlins/grin.gif[/img]. Dual alternators and dual sets of batteries. If I need a jumpstart all I do is push a button. On spot tire chains that install and de-install themselves at the flip of a switch. Also has air compressor on board along with suction unit and O2 system.
1972 Cadillac Hightop Ambulance by Superior Lucky if I get 10MPG
CompuDoc is offline
Old 08-22-2003, 08:47 AM   #5 (permalink)
Yes, GM Dexron, Ford Mercon, same thing. Read the bottle the next time and you will see. You are thinking of back in the old days when they used type F.
