6.0 liter Fuel Filter change - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 06-06-2010, 05:45 PM Thread Starter
How often are my fellow 6.0 van owners changing the fuel filters?
I have heard every 15,000 is recommended at the most but every 10,000 for severe duty.
It takes a lot of will power to be good to that schedule when you have a van & have to deal with that upper filter! I have been a good boy about it but I cringe at the thought of removing all the stuff in the way.
I think It would be nice if we could Buy Just the frame mounted filter seperately & change that every 7500 or 10,000 & then do the upper one at 15,000
Premier Kirby is offline
post #2 of 7 (permalink) Old 06-06-2010, 09:26 PM
clapsrm's Avatar
My Photos: (5)
I have been doing it once a year since ownership (3 times). I cut the mount for the wiring harness a bit so that I can slide it out a bit easier (still a PITA). I suppose it is a little over 15K each time. They have been clear so far but I worry about tank delam. so I am sure to do it each year.
2005
E-350 Super Duty Chateau 6.0 PSD 185,000 miles (Wiring harness relaced (under warrantee), FICM replaced, Alternator, Ball Joints 2x, Motorcraft Batteries (3rd set), Radiator, Tank Delamination and pump, all glow plugs, stabilizer bar, vacuum pump...)
2007 Chevy Express Explorer
2001 Mercury Marquis
2013 StarCraft Autumn Ridge 329
clapsrm is offline
post #3 of 7 (permalink) Old 06-06-2010, 10:07 PM Thread Starter
yea I had the Tank delam issue. The way I found out is that my frame mounted filter had a LOT of silver flakes in it. The Upper one never seen any so thats good.
post #4 of 7 (permalink) Old 06-07-2010, 09:43 AM
Ujoint's Avatar
I swap every 10K no matter what.
02 E350 7.3 - V4
11 E350 5.4 - V5
ujointoffroad.com
Ujoint is offline
post #5 of 7 (permalink) Old 06-07-2010, 07:24 PM
saline's Avatar
Same here.
04 E 350 Sportsmobile 4x4
6.0L PSD
315/75/16 Toyo Open Country MT's
Dynatrac 60 front/ Dana 70 Powr-loc rear, 4:10's
Atlas II x-fer case
Coolant filter
saline is offline
post #6 of 7 (permalink) Old 06-07-2010, 08:42 PM Thread Starter
Just changed out the filters again yesterday. This time I tried lifting the wiring harness up & removing the Power steering bracket. i did it without removing anything else but it was TIGHT & my Forearm is showing it. My 08 has both the 15/16 wrench fitting & a 1/2inch socket drive in the middle of the cap. I find the 1/2 drive way to be easier using a 3/8 ratchet & a adapter to up it to 1/2.
Both filters appeared fine.
post #7 of 7 (permalink) Old 06-07-2010, 09:10 PM
Originally Posted by saline View Post
Same here.
Ditto.
2004 6.0 E350 Quigley 4x4 w/ Sportsmobile Conversion.
285/75R16 BFG AT/KO. 3.73 Gears.
Dieselsite Coolant Filter.
Aluminess Front/Rear Bumpers.
125W Solar Panel.
Sportsmobile Trailer on 285/75R16 BFG AT/KO tires w/ dual deep cycle marine batteries, water pump, 10 gal water storage, air compressor, storage box & 15W Solar Panel.
SnowMan Mod / Door Seal Mod
"Blue Spring" Upgrade
ridintall is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > E-Series Vans
