6.0L van intercooler in 97 Van? - Diesel Forum - TheDieselStop.com
Old 05-19-2009, 12:27 AM   #1 (permalink)
Ears93's Avatar
So I was looking in a Mitchell Collision book and noticed that the 6.0L vans came with an intercooler? Is it possible to use the intercooler and piping from the 6.0 van and the piping where it actually goes into the motor off a 7.3L SD? I am not sure how it is configured on the 7.3 vans how the air is directed from the turbo into the engine. I haven't had it apart that far.
Am I on to something though?
Nick
Nick
97 E350
Extended Cargo
7.3 Stroker
230,000 Miles
Muffler and Cat Delete
Rebuilt trans with updated parts
More to come but I won't bore you with that crap till its done.
Ears93 is offline
Old 05-19-2009, 07:47 PM   #2 (permalink)
I never looked at a 6 liter van, but there must be way more room up front. Take a look at your van, and you will see that there is no room.
2003 E-350 7.3, 38R, DIY intake, 4" turbo back, Swamps Tunes, forged rods, exhaust ported heads, comp 910's, h-11's, stealth twin pumps, 300cc hybrids, racerx trans and tc, water injection
rpm1 is online now
Old 05-19-2009, 08:52 PM   #3 (permalink)
My brother has a 6.0 E-series. They did things like move both batteries to the frame and install a different radiator to make room for the intercooler. An awful lot of packaging went into fitting the 6.0 in the vans. I suspect that a good mechanic with a full complement of tools would be able to see the engine block or a cylinder head of a 6.0L within 15 minutes or so.
My personal feeling is if someone chose to modify the intake resonator, relocate the fuel filter assembly, relocate the battery, relocate the air filters on a 7.3L and switch to a 6.0L radiator, the 2004+ intercooler would work. If I had the ambition to undertake such a project, however, I would be looking at an air-to-water intercooler. More expensive, but a lot cleaner installation.
A few people on this forum have initiated intercooler projects on their 7.3L E-series, but I've never seen a completed one yet. It obviously isn't an easy project.
2003 E-350 14-passenger, 3.73 axle, Quadvan 4x4, AIC, TransferFlow 46 gallon tank, DP tuner, DieHard Platinums, PIAA driving lights, 17" Hakkapelliitas snow tires, 18" Continental ContiTrac summer tires, front receiver hitch
beaker is offline
Old 05-19-2009, 09:09 PM   #4 (permalink)
blageurt's Avatar
There is no way it will work without some serious modifications to the above metioned stuff that beaker mentioned AND the Batteries have to BOTH be moved to the frame and you have to know how to weld like RPM does . . . Otherwise forget it .
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " , DP flashed 60 Tow , 140 V idm , Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K , Timbrens SES kit , replaced lift pump /ICP/ IDM @ 256 K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is online now
Old 05-19-2009, 10:12 PM   #5 (permalink)
Ears93's Avatar
Well, so much for that idea. I guess I should have looked at a 6.0 van first.
Thanks anyway.
Nick
97 E350
Extended Cargo
7.3 Stroker
230,000 Miles
Ears93 is offline
Old 05-20-2009, 07:30 PM   #6 (permalink)
Originally Posted by blageurt View Post
and you have to know how to weld like RPM does . . . .
Thanks blag, but I really am not that good at welding. I tacked all my plumbing together, but I am going to have somebody else weld them up solid. I would have more time grinding than I do in the rest of it!
Not sure if I posted this somewhere already, but here is an idea I had for an a/a intercooler. It would be a LOT of work, but may be worth it to somebody. It would fit in the factory grill area, and then you would need a billet grill. Either cross flow or vertical flow.
rpm1 is online now
Old 05-20-2009, 07:30 PM   #7 (permalink)
rpm1 is online now
